Is it possible to have multiple velocity inlets in your model |
June 5, 2010, 02:29 |
Filip
Rep Power: 16 |
Hi everyone,
I'm new to using Fluent and was wondering whether it’s possible to have multiple velocity inlets. That is to include velocity inlets (mass sources) away from the outside boundary, see figure below. I’m simulating a combustion chamber for my final year thesis and have used ICEM to create the mesh. I have used a pressure inlet for the air entering the combustion chamber and outlet on the opposite side. All other curves on the outside boundary are having a wall boundary layer applied to them. I have 2 fuel lines which are have circular cross section which are located inside the combustion chamber domain. These have been into 4 curves. At the top and bottom holes are present where the fuel enters from. I have created a curve at the top and bottom where the curve is the diameter of the fuel nozzle. I have applied a velocity inlet on these cures and have applied a wall boundary condition o the rest of the curves making up the fuel, circulars in the figure below. The problem is that when I import it into Fluent the curves making up the fuel merge and are no longer split and appear as a continuous circle. I initially thought of just defining an injector but i couldn’t get any flow coming out which was apparent when I looked at the velocity fields and think it will be very difficult to simulate it in this manner as well as require a lot of computer power to simulate combustion. Thanks for any help in advance! Last edited by boundarylayer; June 8, 2010 at 03:54. |
multiple inlets |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
Error message: Insufficient Catalogue Size | Paresh Jain | CFX | 32 | February 3, 2021 03:37 |
maintaining a logarithmic velocity distribution | Morten Andersen | CFX | 1 | January 8, 2007 11:37 |
Velocity in Porous medium : HELP! HELP! HELP! | Kali Sanjay | Phoenics | 0 | November 6, 2006 06:10 |
Multiple inlets problem | Jeff | Main CFD Forum | 2 | August 17, 2005 10:48 |
