1.#qnb
Like Tree2Likes
  • 1 Post By arslan
  • 1 Post By pakk
Old   June 10, 2010, 05:34
Default 1.#qnb
marie
marye is on a distinguished road
when I run my program, it stops at 3 iterations and on Fluent I can read "solution is converged"
and I have 1.#QNBe+00 that appears...
Does anyone know why?
I replace my real by float but it doesn't change the result.
marye is offline   Reply With Quote
Old   August 8, 2010, 18:38
Default Hi
Ehsan Esmaili
Ethan is on a distinguished road
Hey, I am getting the same problem with 1.#qnb. I was wondering how did u replace your real by float?
Thanks
Ethan is offline   Reply With Quote
Old   July 31, 2012, 17:32
Default i had the same problem
ARSLAN
arslan is on a distinguished road
the problem i solved was a very simple: axissymmetric (horizontal) channel. I set up a axis BC at the upper boundary of my channel and get this error:
iter continuity x-velocity y-velocity time/iter
! 1 solution is converged
1 1.#QNBe+00 1.#QNBe+00 1.#QNBe+00 0:00:12 999
when i change: the upper boundary set a Wall BC, and the bottom set the Axis BC all fixed and a solution was gone..
I've heard before that Axis BC must be only horizontal...it seems that this boundary must be also a lower boundary...in my simple geometry at least))))
hope that it will be helpful...to someone..)))
Sai Krishna likes this.
arslan is offline   Reply With Quote
Old   November 15, 2013, 12:07
pakk will become famous soon enough
For those who were directed to this forum by google searching for "QNBe":
1.#QNBe+00 is what Fluent shows when it really does not know what to do, for example when somewhere in the calculation there was a 0/0.
In floating point operations, 0/0 results in NAN (Not Any Number). In Fluent, this is #QNAN. Fluent wants to represent this in exponential notation:
1.#QNANe+00
The next thing that happens is that Fluent wants to represent is with 4 digits. N is bigger than 5, so the A is rounded up to B, and it becomes
1.#QNBe+00
If you see this, it means that something in the calculation went wrong. It can have many, many different causes.
pakk is offline   Reply With Quote
Old   November 16, 2013, 05:52
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
In this specific case, people really should have read the manual.
It clearly states that the axis of symmetry in an axisymmetric simulation has to coincide with the x-axis.
flotus1 is offline   Reply With Quote
Old   November 19, 2013, 13:35
Hem
hem233 is on a distinguished road
In my case, #QNB is coming after around 3500 iterations. So how can I know what is going wrong?
hem233 is offline   Reply With Quote
