Momentum source calculation
Old   June 19, 2010, 14:29
Default Momentum source calculation
Kavita
kavitagangisetti is on a distinguished road
Hi everyone,
I am trying to calculate the momentum source as shown -
source = mdot *(increase in velocity) /cell volume.
where, mdot = mass flow rate through each cell face.
cell volume = volume of each cell in the fluid zone, where source has to be applied.
The flow is steady and fluid is moving in a pipe in x direction.
When i give the calculated source value as x momentum source term in fluent, I am not getting the expected velocity increase.
Can anyone tell me is this the correct way of calculating momentum source
Thanks in advance,
Kavita.
kavitagangisetti is offline   Reply With Quote
Mass source, Momentum source theory. diffo FLUENT 4 August 21, 2009 10:26
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
Warning 097- AB Siemens 6 November 15, 2004 04:41
Setting momentum source for periodic calculation lego CFX 3 December 16, 2002 17:02
