June 28, 2010, 17:38 |
ansys icem to fluent help?
yildirim
Rep Power: 16 |
hi...
how ı can output a ansys icem mesh to fluent.ı dont know,how ı must do boundry conditions. ıt about water fluıd in a pipe. |
June 29, 2010, 02:22 |
Rep Power: 16 |
You should go to Output in ICEM and choose Fluent. Than you can specify your boundry conditions. Wither way, all BC can be changed, and most likely will be, in Fluent. Type of fluid is specified in the solver. |
July 1, 2010, 04:53 |
yildirim
Rep Power: 16 |
ı tryed but ı cant open at fluent.ıt gives error message..
> Reading "C:\Documents and Settings\m\Desktop\projeckt documents\boru\fluent.msh"... 405 nodes. 432 mixed cells, zone 15. Error: read: face 1034, zone 16. Reading Faces: failed while reading section 13. Clearing partially read grid. Error: Read aborted due to critical error. Error Object: () Error: Error reading "C:\Documents and Settings\m\Desktop\projeckt documents\boru\fluent.msh". Error Object: #f |
July 3, 2010, 07:58 |
#4 | |
Wirot
Rep Power: 16 |
In case of Haxa mesh , are you sure that all blocks were associated with geometry's part ? After choose output (ansys , fluent_v6) and set BCs, please notice when you write this input the program warn a complete message or not ? hope this help |
July 3, 2010, 16:56 |
yildirim
Rep Power: 16 |
all bloks were associated...ıt still gives error mesage....
July 7, 2010, 07:41 |
yildirim
Rep Power: 16 |
i tryed to open with fluent but it gives an error message
error: there no cell zone available please read a valid volume mesh i dont understan where i made a mistake... i made mesh with blok i think mesh is volume mesh.... help |
July 7, 2010, 08:21 |
Rep Power: 16 |
I understand your mesh is 3d. If that is the case are you sure you specified "body" inside your geometry?
July 7, 2010, 08:28 |
yildirim
Rep Power: 16 |
yes there is body inside the geometry but i m not sure that is ok i just pick the geometrys different side and body is exist.
drag coefficient in ansys fluent 12.0 | krishna | FLUENT | 19 | April 12, 2018 00:49 |
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 03:34 |
[GAMBIT] 3.5 years overtake by Ansys: Where are the enhancements in grid generation | Volker P. | ANSYS Meshing & Geometry | 22 | January 17, 2012 17:27 |
FLUENT results to ANSYS | Jin Yan | FLUENT | 2 | April 28, 2011 11:22 |
Exporting ICEM Tetra Grid to Fluent with Hexa-Core | Tim | FLUENT | 2 | August 30, 2007 07:16 |
