July 16, 2010, 10:33 |
fluid flow around a half burn pipe
Destry Marulitua Siagian
Dear all..
hi my name is Destry im a student of ITB (Bandung Institute of Technology) Indonesia major in ocean engineering I'm working on my thesis now about fluid flow around the pipe.. I have done a laboratory test. and now need a numerical simulation using FLUENT I examine the flow of water around the pipe that partly buried. There are two cases: single pipe and three parallel pipes .. I am just learning this software .. Please help me how to simulate these with FLUENT to produce velocity and pressure around the pipe .. thanks a lot Regards Destry |
July 16, 2010, 10:50 |
Chris
What specifically do you need help with?
July 16, 2010, 10:55 |
i have make the meshing with gambit,, (but dont know it is a good meshing)
but really dont know how to run them in FLUENT,,, so,, i need steps how to run them n produce the velocity and pressure around the pipe |
July 16, 2010, 11:17 |
Chris
Have you gone through some of the fluent tutorials? That's really the best way to get started and learn how to use the software. Also, the user's guide is actually pretty good at guiding you towards which solver to use, turbulence model, etc. Do you have some specific questions about the software?
July 16, 2010, 11:24 |
#5 | |
actually i have... but the tutorials use a different model with mine,, i have try using the guidance but produce a bad result... btw,,, when running this software will we get a set data of pressure and velocity in each grid? i havent found them yet when i finish run my cases |
July 16, 2010, 11:29 |
Chris
Yes, you should be able to view the velocity and pressure data for your case. You can display them by going to Display-->Contours. Maybe you could post some plots of your solution and grid? Also, what solver are you using, what are your boundary conditions, etc?
July 16, 2010, 11:43 |
here i attach the grid and some of the fluent result..
i use steps in fluent tutorials to produce them http://flowlab.fluent.com/exercise/pdfs/cylinder.pdf so,, the data (pressure and velocity at each grid) will auto saved? how to open them? do they available in notepad format? |
July 16, 2010, 11:51 |
Chris
The data can be saved at whatever interval you choose by going to File-->Write-->Autosave. You can post-process with fluent, or you could use something else, but I'm not really sure why you want to open the data file with a text editor, as the data is not in a reader-friendly format.
Regarding your simulation, what are your boundary conditions? Also, you might think about moving your inflow boundary farther upstream and refining the mesh in the near-wall regions. |
July 16, 2010, 12:01 |
in gambit you mean?
the boundary condition: velocity inlet outflow and wall for pipe and upper n bottom area.. i need the data (velocity and pressure) to calculate scouring with empirical formulas so i cant get them? |
July 16, 2010, 12:14 |
#10 | |
Chris
Regarding the actual simulation, you might try using a structured grid to more adequately and efficiently resolve the near-wall region. Something like this: cylinder-01.jpgcylinder-02.jpg |
July 16, 2010, 12:24 |
#11 | |
i need the average data in front of the pipe after fluid crossing the pipe... may i get the mesh? if it is possible,,may u sent them to my email (sgn_mathiew@yahoo.com) as reference for me making grid in 2nd task (the parallel case) the scouring is such effect of fluid flow around pipe... actually bottom area is not a wall... but soil,, how i define them in gambit? |
July 16, 2010, 13:16 |
#12 |
btw,,,,
thx for helping me today.... Regards Destry |
July 16, 2010, 13:39 |
#13 |
Chris
I hope that the images I attached can be enough of a reference, as I don't feel comfortable sending you the actual grid.
Regarding the wall boundary condition: I you can't set a "soil" boundary condition, but you can set a value for the wall surface roughness to simulate the soil. That might be enough to get you what you need. Although, I might not understand exactly what you're asking. |
July 16, 2010, 21:42 |
#14 |
ok...
thx for helping.... Regards Destry |
High speed compressible flow through pipe | Munni | Main CFD Forum | 6 | December 7, 2015 11:33 |
[snappyHexMesh] Pipe flow / Internal fluid dynamics with SnappyHexMesh | denner | OpenFOAM Meshing & Mesh Conversion | 3 | October 13, 2011 09:24 |
About Turbulence Intensity (Pipe flow assimilated) | gRomK13 | Main CFD Forum | 1 | July 10, 2009 03:11 |
Natural convection - Inlet boundary condition | max91 | CFX | 1 | July 29, 2008 20:28 |
