July 19, 2010, 05:22 |
Injection definition
Dokeun, Hwang
Rep Power: 16 |
Hello
I'd like to repeat the water jet simulation done by Jiangfeng Wang(http://www.worldscinet.com/mplb/24/2...910023475.html) flow region is 152(y)x127(z)x600(x)mm inlet flow is air(M=1.94, P=29000Pa, T=304.1K) form x=0 to normal direction. Injection condition described in this paper is as follows injection position : x=139mm, y=76mm, z=0mm nozzle diameter : 0.5mm mass flow rate : 0.02kg/s temperature : 298.15K initial velocity : 40m/s(to z-direction) initial radius of water droplet : 0.5um All most all parameter can be defined in the injection point properties but, I have no idea how to define the injection nozzle diameter in fluent. Thank you for your kindness in advance |
July 19, 2010, 09:07 |
using cone injection
Dokeun, Hwang
Rep Power: 16 |
I think I may find a way partially to defining the water injection for the problem
Water is injected from a nozzle which has 0.5m for its diameter. So it may be simulated solid-cone injection in which has zero cone angle(=0) and r=0.25m I wonder if I get a right way of.. Last edited by dokeun; July 19, 2010 at 22:47. |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
surface injection or point injection? | sukura_1984 | FLUENT | 0 | September 2, 2009 09:26 |
Spray Injection | usker | Siemens | 2 | April 6, 2007 00:41 |
On DPM injection properties. | akr | FLUENT | 4 | October 23, 2006 10:54 |
using injection file and parallel process | Cindy Jones | FLUENT | 0 | January 23, 2003 12:40 |
