Vacuum with two-phase flow
Old   October 4, 2002, 16:08
Default Vacuum with two-phase flow
Ahmed Khattab
Hi everybody,
I already used FLUENT to model the injection of resin inside a mold, which contains carbon fiber mat, as a two-phase flow through a porous media. The mold is simulated in a 2D as a rectangle with an inlet port on the right side and vent port on the left side. The injection of resin is considered as a two-phase flow, where the volume fraction of the injected resin is one and the volume fraction of air inside the mold, before the injection, is also one. In order to track the resin-air interface the volume of fluid (VOF) model is used. The transient time terms are considered. There is a very good agreement between this model and the previous experimental results. BUT NOW I want to apply VACUUM inside the mold from the vent port and the resin will be sucked from the inlet port at atmospheric pressure. CAN anyone help me in that? How can I apply the vacuum? And in this case what will be the conditions for the two phases, since there will be a vacuum inside the mold not air as in the previous case. Thanks in advance.
Old   August 7, 2010, 00:05
Goker T
gtuncol is on a distinguished road
I'm having the same exact problem, were you able to find a solution?
Thanks.
gtuncol is offline   Reply With Quote
Old   August 8, 2010, 11:38
Jouke de Baar
jack1980 is on a distinguished road
Don't know if you can create a vacuum. You might however use a compressible flow and have a very low pressure at some outlet. This should work and at the same time it could even be a more accurate model of the actual problem?
jack1980 is offline   Reply With Quote
Two Phase Darcy flow with gravity -> problem Cyp OpenFOAM Programming & Development 0 November 17, 2010 07:58
two phase flow + ice phase and breaking soeren87 OpenFOAM Running, Solving & CFD 0 September 19, 2010 10:20
Two phase flow in a distributor Mohsin FLUENT 5 May 24, 2010 02:57
how 2 freeze 1 phase flow field & start lagrangian KK CFX 5 February 14, 2008 16:48
swirling two phase flow Ken Schifftner Main CFD Forum 6 July 10, 2000 14:19
