Two phase T-junction pipe flow Viscous model
Old   September 10, 2010, 06:18
Default Two phase T-junction pipe flow Viscous model
Kortels is on a distinguished road
Air and water runs through an inversed-T pipe separator One tube is the inflow of air and water and the other two are the outflows. I want to measure the percentage of air and water at the two outflows in accordance with the air and water in the inflow. i am using VOF method. The problem is i can't decide which viscous model should i use. Maximum air velocity is 27m/s and water is 0,159m/s. Also max mass flow rate is 0.0106 kg/s for air and 0.049kg/s for water. I think K-epsilon is the right one. Reading the forum laminar is suitable too. Which one do you think is the best?
Kortels is offline   Reply With Quote
High speed compressible flow through pipe Munni Main CFD Forum 6 December 7, 2015 11:33
Two Phase Flow Problem miner15kick CFX 5 October 28, 2010 18:03
Type of Model for two phase flow.. applemango FLUENT 2 July 26, 2010 01:52
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 03:11
Turbulence in a pipe flow JM Main CFD Forum 4 December 21, 2006 04:04
