November 12, 2010, 03:03 |
help:error of dynamic mesh
zhuliang
Rep Power: 15 |
Hi, my friends:
There is a mad error in my creating of dynamic mesh, the attachment picture show the error postionnly the top face of the bowl go up while other required faces keep stationary. The upper meshes' character: Hex/Wedge cooper size 3 The lower meshes's characer: Tet/Hybird TGrid size 3 I just want to let the upper past being suppressed when the mesh is move while the lower part hold its shape. Would you please give me a detail depict of operation process if you have a relative experience on this things. Thank you for advance. Best Regards. Last edited by bright181; November 19, 2010 at 00:59. |
November 15, 2010, 01:22 |
Maxime Perelli
Rep Power: 41 |
handle your model with layering (if it is not already done)
In memory of my friend Hervé: CFD engineer & freerider |
November 18, 2010, 09:04 |
Maxime Perelli
Rep Power: 41 |
define the upper surface from red bracket domain as moving wall, and the 2 lower surfaces (one also belongs to green bracket domain) as stationnary.
You also need to define parameters in Meshing option tab for moving and stationnary entities. Check tutorial 11 - Using Dynamic Meshes
November 19, 2010, 00:56 |
Hi
zhuliang
Rep Power: 15 |
You means to keep the lower part stationary and move the upper part?
Maybe I want to let the lower part go up along the Z axis,so the the 2 surfaces can not be stationary but move up keeping its shape. Do you have any idea? |
November 19, 2010, 04:20 |
Maxime Perelli
Rep Power: 41 |
then define upper surface from red bracket domain as stationnary.
the 2 lower surfaces (one also belongs to green bracket domain) as moving with rigid body. As I can remember you need also to define the green bracket volume as rigid body. For that you need to define this domain as separate one (in gambit you can define it as another fluid domain : Specify Continuum Types PS: moving down the upper surface will give same results: it is just a reference stuff
Dynamic Mesh on Pintle type injector. | herntan | FLUENT | 16 | September 4, 2020 08:27 |
Incylinder dynamic mesh with volumetric reaction | mas | FLUENT | 4 | May 3, 2012 10:22 |
dynamic mesh on a hexa grid | Manoj Kumar | FLUENT | 0 | August 21, 2007 07:41 |
Dynamic mesh + grid adapt = Crash! (Files included | BillH | FLUENT | 4 | July 24, 2007 15:31 |
Help: Is it possible to use dynamic mesh model and | Valery Ponyavin | FLUENT | 1 | September 20, 2003 14:18 |
