January 13, 2011, 18:27 |
Post processing images
Patrick Young
Rep Power: 15 |
I want to display my model with some particle tracks and save an image.
I know that it's possible to display my mesh so that it looks solid, and not like a mesh. How is this done? The search engine was no help as I don't know what the keyword for it is Thanks |
May 24, 2011, 15:55 |
Re
Rep Power: 15 |
Could you let me know if you had found out the answer for this question? I want to do something similar. Thanks. |
May 24, 2011, 16:09 |
MadhuVC
Rep Power: 15 |
probably u might want to play with scene under graphics and animations. You can make the mesh transparent and change the colors and things like that.
May 24, 2011, 16:11 |
Rep Power: 15 |
Thank you for your reply. I have been experimenting with that a little bit, but haven't come across a combination that works as yet. Could you be more specific with regards to the options that I might try? Thanks.
May 24, 2011, 16:21 |
MadhuVC
Rep Power: 15 |
I assume you are able to select zone x in your scene tab and then get into the edit mode, where you see face color on the right, some task bar below it and face, edges on the left.
I usually select the faces, outer faces, lighting and deselect the edges and perimeter lines (basically lines).. then drag the transparent bar to around 30-50 (depending on what you want) and change the color. you should be able to have the solid kind of mesh instead of a wire mesh. hope this helps. |
post processing for KIVA | dirga | Main CFD Forum | 5 | April 23, 2009 10:58 |
Question about post processing | qtian | OpenFOAM Post-Processing | 0 | July 24, 2007 12:44 |
Tecplot for CFX post processing | pantangi goud | CFX | 2 | August 24, 2005 16:42 |
A question about .eps images using CFX5.6 post | Forrest | CFX | 6 | June 18, 2004 03:24 |
Post Processing in FEM | Abhijit Tilak | Main CFD Forum | 0 | April 26, 2004 11:59 |
