Composite wall heat conduction
Old   January 20, 2011, 15:40
Default Composite wall heat conduction
Bojan Petkovic
boki is on a distinguished road
I am modeling heat conduction through several different materials in a cylinder (heating probe with coil, powder core, steel wall). I am using sliding mesh approach and I define interfaces between different regions.
While for 2D problems it is not to much work, in 3D it is just painstaking, I need to create every single interface manually, and then when I do a small change in the geometry, I repeat all that.
Is anyone aware any other approach for this than the Sliding mesh approach?
Thanks!
boki is offline   Reply With Quote
Wall Heat Flux not a listed variable mike CFX 8 February 5, 2009 13:32
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
Heat conduction through solid rib in periodic duct Dieter Fauconnier FLUENT 0 October 7, 2004 08:22
wall conduction, UDF sudh FLUENT 0 June 28, 2004 08:09
Wall heat flux cujo CFX 3 November 6, 2002 03:43
