Multiphase simulation-Very high pressures
Old   January 27, 2011, 07:31
Default Multiphase simulation-Very high pressures
Hass is on a distinguished road
I'm doing a simulation of air-water bubbly flow in a horizontal pipe.
Eulerian, standard k-e (y+=220)
B.C.s-Velocity inlet, Pressure outlet(0 gauge)
First order upwind
My problem is that when I plot/report the static pressure along the pipe centerline, I get very high values (around 1e11 Pa) at the inlet and it reduces to 0 at the outlet. The dynamic pressure for each phase is much more reasonable at around 1000 Pa. What could be causing the pressure to float so much? Do the reference values affect the value of pressure?
Hass is offline   Reply With Quote
Multiphase flow - simulation crashing yschati CFX 14 November 16, 2010 17:29
boundary layer prediction in multiphase simulation Li CFX 0 September 20, 2007 08:20
Multiphase fluid pump simulation jorge CFX 1 September 9, 2007 18:27
Multiphase High pressure nozzle analysis Anant FLUENT 0 December 20, 2005 01:37
Question on starting multiphase simulation Derek Jing FLUENT 2 April 30, 2002 10:32
