simulation of solar water heater
Old   November 9, 2011, 12:04
Default simulation of solar water heater
Anuj Mathur
Anuj Mathur is on a distinguished road
Hey all.............
I have to do CFD analysis of solar water heater and i am new to this software.
so please tell me what boundary condition and which model should i take any special comments also welcomed.
Anuj Mathur is offline   Reply With Quote
Old   November 9, 2011, 14:00
Martin H.
bobmalaria is on a distinguished road
hi,
is the sun supposed to heat up water in a pipe or vessel?
if yes, then start with the fluent heat exchanger tutorials. this is basically what it is, isn't it?
you will need to provide thermal conductivity data for you pipe material and a reasonable energy source term that represents the sun. what exactly that is... well you need to find this in publications or make measurements.
also "good" material properties for the air around the pipe are needed and possibly a small pressure condition somewhere on the edge of the domain.
bobmalaria is offline   Reply With Quote
Old   November 10, 2011, 12:19
Anuj Mathur
Thanks for the reply.
yes sun is used as a heat source to heat the pipe and through which water is heated.
I want to know about which model should i used?
which operating conditions for the inlet and outlet of pipe should i used?
Old   November 10, 2011, 17:15
Martin H.
hi,
again, have a look in the fluent tutorials. they will be part of your fluent documentation and most of them can be found online as well
No one can tell your you inlet boundary conditions. You need to know some flow rates or at least make a good guess of sensible flow rates for your system.
Old   November 15, 2011, 01:23
Anuj Mathur
hey,
I am using mass flow inlet as inlet for pipe and outflow for outlet of pipe.
i am using DTRM radiation model but there is no output. means there is no increment in the outlet temperature. So Plz help what is missing in my simulation.
Thanks.
Looking for information for simulation of explosion in deep water or enclosed space richard FLUENT 6 January 6, 2016 02:06
Simulation of steam (CO2 and Water vapor mixture) flow through nozzle using Fluent. Jimmy FLUENT 0 March 2, 2011 12:30
Solar Radiation Simulation hamedhpt FloEFD, FloWorks & FloTHERM 2 December 12, 2009 08:24
guide me to solve boiling water using heater rizal CFX 5 January 17, 2008 12:32
about disinfection modeling in water Joe FLUENT 3 December 18, 2003 12:58
