Flame not sitting on the burner slot..Plz Help~~ |
February 19, 2011, 09:52 |
ravi teja
I am simulating combustion(2-D) in a multiple slot burner.(7 slots) The chamber is 150mm high and 115mm wide. The fuel(methane+air) slots are 3mm wide and air slots are 10mm wide.Both are separated by a wall of thickness 1.5mm(so that makes 7 fuel slots and 8 sir slots). The fuel inlet velocity is 1.02028m/sec and air inlet velocity is 0.04467m/sec The walls are adiabatic so that heat is lost. My trouble is i cant get stable flames on the burner slots for the above velocities. Can some please point out as to what i might be doing wrong as getting stable flames for the above conditions is important for me to validate the simulations i've done with different velocities. Thank You. |
Combustion Simulation in Multiple Slot Burner | dharanishb | FLUENT | 1 | March 2, 2014 13:30 |
Analysis of Propane Burner Designs | yorzaxt | Main CFD Forum | 0 | July 14, 2010 12:13 |
Flame Lift Off!!HELP!! | dharanishb | FLUENT | 0 | May 31, 2010 09:45 |
Burner anchored laminar flame | Subhash | FLUENT | 0 | August 29, 2004 12:33 |
