Turbulent Viscosity Limit but only showing for imported case
Old   March 9, 2011, 07:35
Default Turbulent Viscosity Limit but only showing for imported case
plunge11 is on a distinguished road
I know getting the error message about the Turbulent Viscosity ratio being limited is very common but I think my particular problem with it is not quite as usual.
If I run a calculation and then reset everything from the setup downwards and then reset the setup to the new values that I want for my next calculation, then this problem does not occur.
However, if I click on setup after running a previous calculation and without resetting everything first then I get the message about the turbulent viscosity ratio. The same thing happens if I import a case file which has been previously run.
It is very inconvenient that I should have to remesh etc. each time I want to run a calculation on a different setup so I was wondering if anyone had a different solution?
Any help would be very much appreciated, thanks.
plunge11 is offline   Reply With Quote
error, turbulence, viscosity ratio
k-epsilon problem: non-physical turbulent viscosity production in coaxial free-jet Felipeb Main CFD Forum 1 July 26, 2010 17:02
Turbulent viscosity and shear rate shib FLUENT 0 June 22, 2010 12:44
Turbulent viscosity level Laurent Dalo Main CFD Forum 0 November 25, 2006 12:27
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
Turbulent Flat Plate Validation Case Jonas Larsson Main CFD Forum 0 April 2, 2004 10:25
