Problems with FLUENT MPI on i7 2600K/P8P67
Old   April 25, 2011, 00:23
Default Problems with FLUENT MPI on i7 2600K/P8P67
Alexander
TaurusASV is on a distinguished road
I have a complicated problem with FLUENT 13 MPI. I open the projects (cas, which was created and results which were obtained (dat) on another computer with version 12.1 of FLUENT and get a message:
> Reading "P:\33_4k-kl-w_2-2.cas"...
Using buffering for scanning file.
7512837 mixed cells, zone 2, binary.
Warning: reading 2 partition grid onto 4 compute node machine;
will auto partition.
7512837 cell partition ids, zone 2, 2 partitions, binary.
18751996 mixed interior faces, zone 11, binary.
459530 mixed wall faces, zone 4, binary.
28000 quadrilateral symmetry faces, zone 3, binary.
28000 quadrilateral symmetry faces, zone 5, binary.
28000 quadrilateral symmetry faces, zone 6, binary.
28000 quadrilateral symmetry faces, zone 7, binary.
25556 mixed velocity-inlet faces, zone 8, binary.
19600 quadrilateral outflow faces, zone 9, binary.
4770662 nodes, binary.
4770662 node flags, binary.
27912 "z227" point-profile points, x, y, z, x-velocity, y-velocity, z-velocity, turb-kinetic-energy, specific-diss-rate.
Building...
mesh
auto partitioning mesh by Metis (fast),
distributing mesh
parts....,
faces....,MPI Application rank 3 exited before MPI_Finalize() with status -1073741819
999999 (..\src\mpsystem.c@1149): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 4 bytes: Invalid argument
The Parallel FLUENT process could not be started.
I mean this is a problem with starting MPI (hp-mpi or intel mpi). On another computer I didn't have such errors with this files.
The firewall on the compure is turned off.
The same problem I have if I use versions 12.1 and 6.3.26. Without any differense.
I tried to update hp-mpi from HP site and get version 8. But it did not solve my problem.
I tried to reinstall OS (W7 x64) and ANSYS (13 and 12.1), but errors were the same.
I believe that core i7 k2600 on ASUS P8P67 had some incompatibility with ANSYS software when MPI used.
TaurusASV is offline   Reply With Quote
Old   May 5, 2011, 11:58
Default thinking of purchasing this processor
Rob Stringer
bathrob is on a distinguished road
Hi Taurus,
I am currently a PhD student and will shortly be purchasing a computer with the i7 2600k processor (although with a intel motherboard) with the intention of running Ansys CFX 12.1 and probably OpenFOAM. I was just wondering if you had resolved this issue or know whether or not it is a compatibility issue with the processor specifically? It'd be a nightmare if I couldn't parallel process on it! One possible solution is to switch off the hyperthreading in the bios. I have seen CFX 11 working fine on an earlier version of the i7.
bathrob is offline   Reply With Quote
mpi fluent errors
problems with Fluent display windows chris FLUENT 3 January 7, 2016 10:44
[ICEM] Problems with export 2D mesh from ICEM to FLUENT newcomer ANSYS Meshing & Geometry 54 September 20, 2014 12:40
Fluent jobs through pbs ibnkureshi FLUENT 5 June 9, 2011 13:43
Problems starting parallel fluent on linux HSeldon FLUENT 6 June 13, 2008 11:25
Error using LaunderGibsonRSTM on SGI ALTIX 4700 jaswi OpenFOAM 2 April 29, 2008 10:54
