March 8, 2011, 04:57 |
Divergence detected in AMG solver : k
Tarik Bennani
Rep Power: 17 |
hello,
I am currently trying to simulate a water flow into a nozzle for a atomisation. It's an internal flow with very small dimensions. I am using the VOF method, with the water flow going through the air. Transient flow and turbulent (Realizable k-epsilon) are my conditions. I have a Reynolds (for the Inlet) of about 3500. I used a velocity inlet and pressure outlets. I used the turbulent intensity (that i calculated as a 5,7%) and turb viscosity ratio (that is around 12%) My time step is 5e-7s, but my calculation always seem to diverge. (It says for the initialization that the courant number is around 3, but it gets very quickly to a higher number than the 250 bar over which Fluent doesn't continue) Do i just adjust manually the under relaxation factors ? Is there may be something that some of you might help me with ? Thank you in advance. Tarik. |
May 13, 2011, 01:31 |
J.-H. Wang
Rep Power: 15 |
I have encountered a similar problem... adjusting the under relaxation factor doesn't seem to work on me.
Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 11:34 |
ERROR: divergence detected in AMG solver | black mamba | Main CFD Forum | 0 | April 19, 2010 15:15 |
divergence detected in AMG solver !!! | yansheng | FLUENT | 0 | September 27, 2007 11:22 |
DIVERGENCE detected in AMG solver ENTHALPY | MANOJKUMAR | FLUENT | 2 | December 25, 2005 09:54 |
divergence detected in AMG solver: | Shekhar Jain | FLUENT | 1 | September 18, 2003 09:31 |
