Need help for simulating constant pressure combustion in fluent |
March 18, 2014, 14:43 |
shanglong
Hi all,
I am simulating a 1-d constant pressure combustion problem in chemkin.It is a premixed laminar flame simulation.Mass flow inlet and pressure outlet.For this problem, we don't need to worry about momentum equation because pressure has already known. We only need to solve continuity equation, energy equation, species equation and ideal gas equation. Now I want to do the same thing in Fluent.However, it seems like difficult to set up a constant pressure condition in fluent.Does anyone has any idea about this?or can I disable momentum equation individually?I try to use DEFINE_SOURCE in UDF to eliminate momentum equation,but i don't know if is a correct way to do this. Is there anyone knows how to set up a constant pressure condition for a 1-d pipe?or how to disable momentum equation? Thanks Last edited by Shanglong; March 19, 2014 at 07:31. Reason: clarify question |
chemkin, combustion, momentum source, pressure and velocity, udf |
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 09:07 |
Setting Pressure in FLUENT | sampathevs | FLUENT | 2 | August 10, 2013 01:19 |
Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 13:45 |
Pressure BC for combustion chamber | Giuki | FLUENT | 1 | July 19, 2011 11:35 |
pressure inlet bc in fluent | nikhil | FLUENT | 0 | June 28, 2010 16:30 |
