Help with electrical conductivity in Fuel cells |
June 17, 2011, 06:11 |
Golnaz
Hi everyone,
i am tring to model a PEM fuel cell using fluent i have gone through the related tutorial and the fuel cell manual. I have a nonisotropic electrical conductivity. we also i have specofic values for in plane and through plane electrical conductivity in unit on S/m. what i understood, from the tutrial and the manual i would need to used UDS to be able to input the two values for electrical conductivity. but, my problem is that when i try using UDS diffusivity with the orthogonal option the values that i can put in are in kg/ms!!! but the values that i have are in S/m(unit of electrical conductivity) !!! I really dont understand how can i do that, it seems like am missing something, or misunderstanding some part. whats more, i dont understand how the UDS diffusivity can be defined as the electrical conductiviy.. Any Input is much appreciated.. Many Thanks |
June 17, 2011, 11:46 |
MASOUD
Rep Power: 17 |
Golnaz,
UDS is a general concept which can be employed to solve various problems. Fluent can not understand what variable we intend to model through UDS. That's why you find the unit of diffusivity as m/s. You just enter your value in S/m and go ahead with that. Hope this helps. |
June 17, 2011, 15:41 |
Golnaz
thank you Masoud for your reply...
i will try that.. but how dose fluent realise that this input value in the uds diffussivity is the electrical conductivity...?! especially that its showing the unit as kg/s.. many thanks |
June 17, 2011, 16:21 |
MASOUD
Rep Power: 17 |
Well, Fluent doesn't have to recognize what that is.
The UDS equation you probably are going to define is : D[-(Electrical Conductivity) x D(Potential)]=(0 or Volumetric Current Density) These terms just have to be consistent. If you define the first term in S/m and specify the electronic potential boundary condition in Volt and the source term in A/m3 you will be all set. |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
physical boundary error!! | kris | Siemens | 2 | August 3, 2005 00:32 |
