June 23, 2011, 05:31 |
Time discretization
Pejman Sho
Rep Power: 16 |
Dear Friends,
Does anyone know what is the method that Fluent use for the second order time discretization? Regards, Pej |
June 23, 2011, 08:38 |
anil
Rep Power: 14 |
When second-order accuracy is desired, quantities at cell faces are computed using a
multidimensional linear reconstruction approach. In this approach, higher-order accuracy is achieved at cell faces through a Taylor series expansion of the cell-centered solution about the cell centroid. |
June 23, 2011, 08:51 |
Pejman Sho
Rep Power: 16 |
Dear Anil,
Thanks for your reply. I think what you mentioned is mostly about the spatial discretization not the temporal (time) discretization. Do you know which scheme does Fluent use to descritize time with 2nd order accuracy? Something like Runge-kutta, Adam Bashforth,...? |
fluent, second order, time |
Floating point exception error | Alan | OpenFOAM Running, Solving & CFD | 11 | July 1, 2021 21:51 |
SLTS+rhoPisoFoam: what is rDeltaT??? | nileshjrane | OpenFOAM Running, Solving & CFD | 4 | February 25, 2013 04:13 |
Full pipe 3D using icoFoam | cyberbrain | OpenFOAM | 4 | March 16, 2011 09:20 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
