July 11, 2011, 03:53 |
sudden jump of value at interface
raymond
Rep Power: 16 |
Hi, I am beginner in Fluent. my model involved interface. When I did my model in steady state, the velocity distribution seem nice as attached. However, when I did it in unsteady state, there was sudden jump at the interface. I totally do not have any idea to solve it. Pls help me. It is urgent. Any solution in solving my problem? Thanks for help.
July 11, 2011, 08:19 |
At interfaces we have non-conformal meshes and when you have considerable gradients near interfaces, you see such discontinuities. So, revise your gird, try to reach uniform grid. |
July 11, 2011, 13:01 |
#3 | |
raymond
Rep Power: 16 |
Thanks for your help. In order to reach uniform grid, do I need to refine the grid size or using other type of grid around the grid? Thanks for your help since I totally have no idea on it. Thanks. Best regards |
July 11, 2011, 15:00 |
#4 | |
Actually, this jump is due to sudden size change across interfaces. Usually refining the grid and reducing size change can improve your result but you may need lots of cells to achieve that. Maybe you can change topology in order to reduce non-conformality and also size change. In addition, you can also use unstructured grid with proper size function. Amir |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 07:22 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
