June 3, 2011, 13:50 |
Fluid Structure interaction (FSI)
yuaf
Hi friends,
Is there anybody who give me some more information and details about the implementation of the FSI On the fluent Software, I would be grateful if you send me some FSI tutorials or any relevant files which can help me in this regard. Does anybody has any special UDF or... Thanks, Oshin |
June 14, 2011, 17:44 |
Rep Power: 15 |
FSI is a multiphysics problem and can be solved using ANSYS or COMSOL but not Fluent. I am not sure if Fluent 12/13 has some integration capabilities with ANSYS for carrying out FSI.
June 15, 2011, 11:45 |
#3 | |
It is possible to model FSI with ansys-fluent in one way; for two way modeling, you can use ansys-cfx. |
June 15, 2011, 16:52 |
Rep Power: 15 |
Hi osirous, Amir is right in one way. I did not think about it. You can estimate pressure acting on a structure from the flow field solution in Fluent and use ANSYS to perform a stress/strain/deformation simulation, and vice versa. What I was thinking of "real" FSI problem is a strongly, bidirectionally coupled problem between the fluid flow/pressure field and the solid deformation. For that, it is CFX or COMSOL.
July 1, 2011, 20:00 |
Rep Power: 15 |
Hi osirous, I might be wrong. Please look at this post:
http://www.cfd-online.com/Forums/flu...ll-fluent.html He is actually trying to do this problem in Fluent by specifying the fluid pressure on the wall and using an UDF to solve for the wall deformation. He is presently having issues with making a dynamic mesh. Perhaps, you two can collaborate if you like. |
July 5, 2011, 15:38 |
yuaf
Hi skullCFD, Thanks for your help. in fact I read some papers that manipulate FSI in fluent using UDFs and journal files that's why I ask you guys to help me if you have any special information about this procedure.
Thanks |
fsi |
Fluid Structure Interaction using icoFsiFoam Problems | lr103476 | OpenFOAM Running, Solving & CFD | 79 | August 7, 2014 09:30 |
Fluid Structure Interaction | fw407 | OpenFOAM Running, Solving & CFD | 9 | February 14, 2013 17:25 |
Fluid Structure Interaction and OpenFOAM capabilities | paka | OpenFOAM Running, Solving & CFD | 1 | June 6, 2007 13:56 |
Optimization or fluid structure interaction | Steve_NTUA | Main CFD Forum | 9 | August 29, 2006 03:40 |
Fluid & Structure Interaction... | nesusa | FLUENT | 1 | March 31, 2002 21:30 |
