modelling a porous wall as outlet
Like Tree2Likes
  • 2 Post By Ralf Schmidt
Old   October 27, 2006, 09:03
Default modelling a porous wall as outlet
Swen
I want to modell a filter to seperate particels.
Can I use a porous wall as outlet boundary to seperate injected particel?
And how I define a the porous wall as boundary condition?
Thanks for your help Swen
Old   October 27, 2006, 10:34
Default Re: modelling a porous wall as outlet
Ralf Schmidt
Hi!
I dont know about particles, I think, there is a udf needed...
You can define your porous wall as a "porous jump". It is like a internal edge, but with the properties of a porous medium.
The parameters of the porous jump can be derived from the geometry of the filter.
It is not possible, to use the porous jump as outlet. I would modell a region beyond that outlet (if you have a pipe, model additional 2*d, if it is the exit from a container, modell the surrounding to a certain extent) and than set a pressure outlet condition.
Hope, it helps
Ralf
navidvbvb and aydin1989 like this.
Old   November 1, 2006, 08:12
Swen
Thank you very much, i modeled the porous jump and added some volumen after this and it works ...
Swen
Old   July 10, 2011, 07:42
zohreh
zhhjll is on a distinguished road
hi
I want to model a filter in order to separate particles!! did you use porous jump with particles? did this boundary condition capture particles and do separation in good way??
you answer is very important for me
thanks a lot
regards
zohreh
zhhjll is offline   Reply With Quote
Breathing wall and its energy modelling rabetabbevon Main CFD Forum 0 October 28, 2010 04:22
porous modelling abhime12 Phoenics 2 November 11, 2009 09:30
Opening Vs outlet BCs and temporary wall issue Sam CFX 0 January 16, 2008 18:59
reg porous wall as boundary karuna FLUENT 2 May 23, 2006 00:52
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
