Spiral coil heat exchange
Old   August 11, 2011, 23:57
Default Spiral coil heat exchange
luznyr is on a distinguished road
Hi, I'm new to Fluent and trying to model a spiral coil (with cold water flowing through it) inside an enclosure with hot air flowing normal to the coil. I have made the geometry and mesh but I am unsure about the boundary conditions to use. I was hoping to use coupled boundary conditions however this option doesn't appear and it says I need to state a wall temperature or flux. I have also tried merging the coil and enclosure in geometry however this removes the water fluid zone in Fluent. Does anyone know how to model this? (I am trying to find the average nusselt number on the inside and outside of the spiral coil and the temperature of the water around the coil).
Sorry if this is in the wrong section, I wasn't sure if it would come under meshing or Fluent.
Thanks in advance
luznyr is offline   Reply With Quote
coupled bc, exchanger, heat transfer, spiral coil
How to draw a spiral shaped coil using Star-Design Harendra Siemens 2 April 10, 2011 08:44
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
heat transfer: air in a room and water in a coil Alberto CFX 2 May 9, 2006 09:56
HEAT-TRANSFER & EXCHANGE HEAT MODEL Problems Jordi FLUENT 1 March 31, 2006 10:30
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
