Mesh Quality
Like Tree2Likes
  • 1 Post By -mAx-
  • 1 Post By -mAx-
Old   August 22, 2011, 19:55
Default Mesh Quality
Mohsin Mukhtar
Mohsin is on a distinguished road
Hello
For a good quality tetrahedral volume mesh on a cylinder, is it compulsory to mesh the outer faces of the volume as Tri-Pave? or is it fine to mesh the faces with Quad-pave..Please expalin
Thank you
Mohsin is offline   Reply With Quote
Old   August 23, 2011, 01:46
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
for a cylinder, I think you can afford to mesh it with hexa (cooper).
Mesh one cap surface first (with pave)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   August 23, 2011, 02:06
husker is on a distinguished road
If you would like to fill the cylinder with tetrahedral you have another option. You can mesh surfaces with quads then create one set of pyramids and then fill with tets.
Hope this helps
husker is offline   Reply With Quote
Old   August 23, 2011, 02:25
Mohsin Mukhtar
Thank you for your replies
Well, the following picture shows the geometry. It's hard to mesh it via hexahedral scheme hence i would like to mesh it via tetrahedral scheme but the quality of the mesh is very low via tetrahedral. Could you explain how can i approach this problem.
Thanks
Old   August 23, 2011, 02:32
-mAx-'s Avatar
Maxime Perelli
*Mesh cylinder first (one cap with quad).
*Then split the block, like I did for instance.
*Mesh the yellow volume with cooper (mesh source face in front of you)
*Then mesh the orange and pink volumes. Source faces are the one on the top of volume
Mohsin likes this.
Old   August 23, 2011, 07:04
Mohsin Mukhtar
just wanted to know, how did u split this volume?
You first made vertices, then arcs and then from arcs u made face and split?
Old   August 23, 2011, 07:09
-mAx-'s Avatar
Maxime Perelli
Exactly
Mohsin likes this.
Old   August 24, 2011, 01:43
Mohsin Mukhtar
The split operation as u mentioned, gives an error. Can u tell me the reason why is it doing like this? I created another thread:
http://www.cfd-online.com/Forums/fluent/91823-volume-split-face.html#post321285
Please reply
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[ICEM] trouble with mesh quality from ICEM in CFX Solver escher25 ANSYS Meshing & Geometry 0 February 28, 2011 07:38
[snappyHexMesh] mesh quality control and fix tachyon_me OpenFOAM Meshing & Mesh Conversion 0 October 6, 2009 12:48
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
