evaporator design including external flow
Old   September 26, 2011, 04:34
Post evaporator design including external flow
premchand reddy
coprem is on a distinguished road
Hi
I am working on boiling in evaporators.
Domain description:
1. tube body
2. inner fluid
3. fins body (fin body is modelled as porous medium)
4. external air body
i am having liq- refrigerated, vap-refrigerant and air as different fluids that are to be modelled.
i selected mixture model in multiphase flow with 3 phases. i specified primary phase as liq- ref, secondary as vap-ref and secondary phase as air.
my question is : in the inner fluid domain there should not be any air and in the external air domain there should not be any liq and vap-refrigerant. so is this possible to model.
and how to model porous medium with air flowing in with out any refrigerant.
this model is working fine in single phase flow .... i am new to use multi phase model. so can any one help in this.
Regards,
Premchand
coprem is offline   Reply With Quote
boiling, evaporate, flow boiling, heat exchanger, multi phase flow
Best settings for solar car external flow problems kdrbrk Main CFD Forum 0 July 16, 2010 02:18
Why Re is different for external and internal flow john FLUENT 3 June 14, 2007 03:53
Why Re is diff for external and internal flow? john Main CFD Forum 1 June 13, 2007 02:58
Reversed flow on external aero problem Ben FLUENT 2 August 22, 2006 10:05
External Flow Computations - Lift and Drag Ramanath KS Main CFD Forum 9 December 28, 2000 17:38
