Mass flux is not converging
Old   November 9, 2011, 06:57
Default Mass flux is not converging
prince
prince_pahariaa is on a distinguished road
Hii everyone
I am using fluent as solver. From residuals plot, i have observed my solutions are converging (I have kept residuals of the order of 0.001). After some 300 iterations i got message from fluent interface also that my solution are converged.
But on post processing, i found my mass flux is not converged. What probably can be the reason ??
My problem involves high reynolds number. I am using k-epsilon RNG model. I have given velocity inlet and pressure outlet as Boundary condition.
prince_pahariaa is offline   Reply With Quote
Old   November 9, 2011, 12:19
Zachariah Swetky
swetkyz is on a distinguished road
How big are your final mass flux residuals? Also, could you clarify what inlet velocity or mach number you are using?
swetkyz is offline   Reply With Quote
Old   November 10, 2011, 01:51
prince
hii swetkyz
Thanks for taking interest.
I have kept inlet velocity as 2.8m/s which is converted to around 83 kg/s for my geometry. I am getting mass flux at outside which fluctuates in the range of around 70kg/s to 110kg/s.
My problem constitutes a big pool (8.37m*3.14m*9m). From inlet pipe water is supplied into pool through 10 nozzles which is mounted on pipe. In the mid of pool, there is small cube (1m* 1m*1m) from where pipe is installed to takeout the water from the pool.
Old   November 10, 2011, 02:55
laurentb's Avatar
Laurent B
laurentb is on a distinguished road
You can - check your mesh quality
- try to reduce residuals to 0.0001 or less
- use double precision solver
laurentb is offline   Reply With Quote
Old   November 10, 2011, 08:25
Zachariah Swetky
I often turn off automatic convergence. You can watch the mass fluxes by creating monitors and setting them to plot and write.
It may help to turn on "pseudo transient" as well. Oscillations should damp out a little sooner using this feature. You can also try reducing the Under-relaxation factors to see if it will converge better. However, make sure that you finish your solution with the energy under-relaxation factor as 1.0.
Old   November 10, 2011, 23:26
neville
neville is on a distinguished road
Please try to reduce UDF's for momentum. Also try using a higher order scheme for pressure and momentum.also set your residuals to E-06. It should work.
neville is offline   Reply With Quote
Old   November 11, 2011, 00:59
prince
Hii laurentb
I was using 3d and not double precision solver. Lemme check.. Mesh quality is around 28%. Is it good ?? I am using T/Grid type of mesh.
Thanks
Old   November 11, 2011, 01:18
prince
Hii swetkyz
I am not able to find pseudo transient option. Can you guide me through it?? I have decreased the relaxation factor and waiting for results. Lets see
Thankss
Old   November 11, 2011, 01:21
prince
hii Neville
I have decreased the URF value for momentum from default 0.7 to 0.3 and i also set the residuals below 1.0E-06. Lets see whether it will work or not
Old   November 11, 2011, 01:55
Far
Sijal
Hii swetkyz
You can turn on pseudo transient option by enabling the solution to be the unsteady with some specified time step and no of time steps. Check the convergence of your parameters of interest and when it reaches the steady state value, stop the run
Old   November 14, 2011, 08:34
Zachariah Swetky
Originally Posted by prince_pahariaa View Post
Hii swetkyz
Thankss
Hi Far,
pseudo-transient is a check-box at the bottom of the "Solution Methods" panel. You can also turn it on through the TUI.
Old   November 14, 2011, 08:59
Far
Sijal
good addition to my knowledge. Is this available for Fluent 6.3 and Fluent 12.?
Old   November 15, 2011, 06:41
prince
I couldnt find "Solution Methods" panel. I am using fluent 6.3.26 But was able to activate pseudo transient by the method described by Far.
As i described earlier also, in my problem, water from inlet pipe ( L shaped) is supplied into pool through 10 nozzles which is mounted on pipe. In the mid of pool, there is small cube from where pipe is installed to takeout the water from the pool. I am uploading picture of my geometry for better understanding.
After activating pseudo transient mode my overall mass flux is conserved but flow of water from nozzle into the tank is not what i expected.
I was getting the expected value for nozzle when pseudo transient were not activated. I also have tried other suggestions but not much of help.
Looking forward for any more help
Old   November 16, 2011, 01:34
prince
Hii friends
Problem at last seems to converge. Mass flux is pretty okay and supply through nozzle also coming as expected.
thanks for all your's valuable input
Regards
Prince
Old   November 16, 2011, 03:30
Far
Sijal
Originally Posted by swetkyz View Post
Hi Far,
I am using Fluent 12.0 and 6.3, but I am unable to the locate the pseudo option in solution method panel. Can you please describe how to activate this option step by step?
Old   November 16, 2011, 11:08
Zachariah Swetky
It may not be available in those versions. I am using version 13.
Problem setting with chtmultiregionFoam Antonin OpenFOAM 10 April 24, 2012 09:50
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
total mass flux correction for compressible fluid? Francesco Di Maio Main CFD Forum 0 August 21, 2000 04:23
