visualization of cavitation on propeller blades
Old   November 15, 2011, 05:38
Default visualization of cavitation on propeller blades
Emre G
emreg is on a distinguished road
hi..
how can i visualize the cavitation on propeller blade surface especially vapor/bobble occurrence on surface where cavitation exists?
is a CFD-post software necessary for that?
thanks,
emreg
emreg is offline   Reply With Quote
Old   November 15, 2011, 09:02
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Assuming that you have used the mixture model coupled with one of the cavitational models, you have only to plot contour of vapor fraction of secondary phase (vapor).
Daniele
ghost82 is offline   Reply With Quote
Old   November 15, 2011, 09:49
Emre G
hi
residual vf-phase-2 appears allways zero during whole of the transient iteration
other residuals change meaningly.
i dont know why vf-phase-2 doesnt change
could u help me plz
Old   November 18, 2011, 11:10
ghost82's Avatar
Rick
Vapor residual is 0 because in your simulation cavitation doesn't occour for some reasons:
- Are you sure that cavitation occurs? what is your cavitation number?
- What are your boundary conditions?
- What is the quality of your mesh?
- What time step are you using for the transient cavitation?
In my experience you have to use a good quality mesh, with appropriate cell size able to capture cavitation; also you have to use small time step (I often used 10^-6 - 10^-7 s).
Old   November 18, 2011, 14:04
Emre G
hi,
i hav an 10 million tetra mesh >>> 2 million polihedral.
i visualize vapor fraction by displaying contours, it solved cavitation already, but vf-phase 2 still remains zero. pfff.
time step : 1 degree.
Old   November 19, 2011, 06:44
ghost82's Avatar
Rick
Cavitation isn't solved if vapor fraction is 0; this means that cavitation doesn't occur in your simulation.
Explain your case:
- are you moving the blade?I haven't experience with moving frames, I only simulated cavitation (steady and transient) by moving the liquid.
- If you are moving the blade, what is the rpm value?For example, if your blade is at 30 rpm you have 180 degree per second, this means that 1 degree is accomplished in 5.55e-3 s..I recommend to low this value till 10^-5 - 10^-6.
- I recommend to check your grid and to size cells where you think that cavitation occurs near 0.125 mm3 (tet size near 0.5 mm).
Old   November 19, 2011, 16:24
Emre G
i didnt say vapor fraction is zero..
i am talking about vapor phase 2 Residual... it remains zero..
observing vapor.
Propeller calculation toil CFX 15 May 22, 2017 04:06
Centrifugal Pump Cavitation problem or not. ismael.s CFX 13 February 27, 2012 08:00
Combining Cavitation and Thermal Effects? akash_max CFX 4 January 19, 2012 14:09
Modelling a propeller tomg STAR-CCM+ 4 April 28, 2011 17:22
360 degree fluid zone for a 4 blade propeller s0me0ne CFX 5 June 27, 2010 07:09
