Mixture model for nanofluids
Old   December 7, 2011, 04:17
Default Mixture model for nanofluids
sima
sima_udf is on a distinguished road
I want to use mixture model for nanofluids in fluent but I want to change the the fluent defined viscosity and thermal conductivity of mixture. I want to use another formula for these properties.
How can I do this?
Thanks.
sima_udf is offline   Reply With Quote
Old   December 7, 2011, 05:15
Amir's Avatar
Amir
Amir is on a distinguished road
Originally Posted by sima_udf View Post
How can I do this?
Thanks.
Dear Sima,
I also did some investigations in nano-fluids field; as I know, multi-phase modelling in not proper for this purpose! you can easily use scalar transport equation. In order to define new variables, you can write simple UDFs which define these properties as functions of volume fraction.
Bests,
Amir
Amir is offline   Reply With Quote
Old   April 15, 2020, 19:58
Default Did you solve the problem
Abhi
abhilasht is on a distinguished road
How can I do this?
Thanks.
I`m facing problems in mixture model for the same simulation. Did you complete the simulation? Kindly help me. Tell me the steps. How to assign phase velocity using mixture velocity data.
abhilasht is offline   Reply With Quote
Old   April 16, 2020, 02:03
Default Properties
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
If you want to modify properties and you want to use some formulation that is unavailable in Fluent, then you just need to write UDF. Property UDFs are usually simple. Look at the example at
https://www.afs.enea.it/project/nept...udf/node46.htm
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 16, 2020, 02:10
Abhi
Dear Sir,
I`m having mixture velocity and for velocity inlet boundary condition, it is asked to provide velocity of different phase. How can I get phase velocities using mixture velocity data. Kindly help me.
Old   April 16, 2020, 02:19
Default Velocity at Inlet
vinerm's Avatar
Vinerm
If you have no information of different phase velocities at the inlet, then you can apply same for both. You can certainly determine if there could be a significant difference in their velocities or not. If the inlet of you domain is located at such a location that the fluid has traveled a rather long distance before it, then you can safely assume that both phases would have similar velocity. Otherwise, you can estimate a value using either drift flux models or slip models. However, you need to know the regime of the flow for that since there are always some coefficients in these models that require knowledge of the flow regime, such as, bubbly or not.
Regards,
Vinerm
Fluent's Mixture model in CFX FLuentSwitch CFX 14 December 27, 2014 09:15
A question about UDF utility in mixture and multiphase model aleisia Fluent UDF and Scheme Programming 0 June 7, 2011 16:32
species transport model or mixture model?HELP zhhjll FLUENT 3 March 5, 2011 15:27
Mixture model for Multiphase flows sandisk FLUENT 0 January 23, 2011 18:05
MULTIPHASE - FREE SURFACE & MIXTURE MODEL Aris FLUENT 3 April 28, 2009 11:46
