Home > Forums > FLUENT
Problem in hard-linked faces meshing (periodic boundary)
Old   January 4, 2012, 03:36
Default Problem in hard-linked faces meshing (periodic boundary)
Adji Achmad
aajb is on a distinguished road
Hi everyone,
I've been working around this hard-linking thing for a week and have not found any closure.
I'm modelling a 1/6 section tank in GAMBIT and the tank has some spheres inside (cut in the inner faces).
My problem is more or less the same with this guy posted here Hard-linking faces in Gambit (periodics) 10 years ago.
As for me, the loop orientations are always incompatible to each other so the meshes are extremely skewed, and it ain't pretty.
Anybody could help? This is really confusing me. Any comment will be appreciated.
aajb is offline   Reply With Quote
Old   January 4, 2012, 05:04
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
can you post a picture for a better understanding
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   January 4, 2012, 06:21
Adji Achmad
Hi, Max.
Originally my problem has rather more complex geometry, for simplicity, I down-scaled my problem to:
another angle:
Problem A:
I want to apply the periodic boundary on these faces (so I can apply the rotational periodic in FLUENT later):
and
Then, I start to hard link the faces:
and
(you may notice the loop orientation)
and then, mesh successfully:
Let's say that problem A is solved.
Problem B:
But, when I tried to do the same thing to the sphere at the center
hardlinking:
(you may notice the orientation is reversed from problem A)
The meshed face is highly skewed:
I understand that this happened because of the loop orientation between Problem A and B is reversed, and when I tried to apply the reverse orientation radio button, the hard-linking just didn't work.
I don't know how to work around this problem since I cannot change the orientation.
I hope I explained the problem more clearly, please let me know your suggestions.
Old   January 4, 2012, 06:54
-mAx-'s Avatar
Maxime Perelli
don t see any picture
Old   January 4, 2012, 07:10
Adji Achmad
yep, I'm using imageshack, maybe I should try to move it to another hosting. Anyhow, you can see the pics by right-click -> open image in new tab
Old   January 4, 2012, 07:18
-mAx-'s Avatar
Maxime Perelli
you can reply with "Go Advanced", and then upload pictures on cfd-online
Thread Tools
Trackbacks are On
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 prashanthreddyh ANSYS Meshing & Geometry 1 December 20, 2011 00:35
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
[ICEM] Problem with meshing (uncovered faces, can't export bocos) hectordiaz ANSYS Meshing & Geometry 16 May 13, 2011 06:36
Import problem ARC Open Source Meshers: Gmsh, Netgen, CGNS, ... 0 February 27, 2010 10:56
GAMBIT meshing problem for boundary layer Falah FLUENT 1 October 9, 2006 03:32
