fluent inlet velocity setup
Old   February 19, 2012, 23:18
Default fluent inlet velocity setup
Linyx
linyx is on a distinguished road
HI everybody
I have a problem running fluent, l am simulating a air flowing through a wing, since it is a low velocity problem, I do not have to think about the mach effect. In gambit, I construct the wing with a cord length of 1m, for convenient sake, and set flow velocity of 200m/s in order to maintain the Re. the inlet boundary type in velocity_inlet and outlet boundary type is pressure_outlet. is it OK to set up like this? I mean the inlet velocity is near the c, which is the sound velocity, will the flow generate the shock wave?
Hoping for answers!
linyx is offline   Reply With Quote
Old   February 20, 2012, 03:55
federvo.mala is on a distinguished road
Originally Posted by linyx View Post
HI everybody
Hoping for answers!
You are in the transonic regime, therefore (maybe) some local supersonic areas might occur on the wing with related shock and compression waves.
I have never treated supersonic flow in Fluent so far, but I think you are going to take care of the supersonic effects in the setup. I don't know how, I think there might be a tutorial.
federvo.mala is offline   Reply With Quote
Old   February 22, 2012, 03:23
Linyx
Actually, I have simulated it in the fluent, yes, the velocity is around the transonic region, but the there seems no shock wave, and velocity contour is more or less the same to the simulation of the actually model(20m in chord, 10m/s in velocity). Do they happen to be the same, or is there any reasons behind them.
Old   February 22, 2012, 11:09
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
try pressure far field with your corresponding mach number...
Ali.
diamondx is offline   Reply With Quote
Old   February 23, 2012, 00:05
Linyx
Actually, I am simulating a low velocity problem, I just want to konw if it is ok to set the chord length 1 and corresponding inlet velocity of 200m/s, which maintains the Re number. the lift and drag are the same according to my simulation result.
Old   February 23, 2012, 11:36
Robert
Hypersonicflow is on a distinguished road
the Reynolds number might be the same, but your Mach number is not. At V=200 m/s, I estimate your Mach number is around 0.6, which is larger than 0.3. Hence, you will get additional effects of compressibitily in your surrogate "high speed" case. For maintaining the Reynolds analogy, rather increase the pressure than the speed.
Cheers, Rob
Hypersonicflow is offline   Reply With Quote
Pressure Inlet VS velocity Inlet difference Mohsin FLUENT 9 January 4, 2021 10:34
pressure inlet bc in fluent nikhil FLUENT 0 June 28, 2010 16:30
velocity more than INLET velocity neu FLUENT 3 May 13, 2003 04:56
Settling Velocity - FLUENT Discrete Phase Model Lily FLUENT 2 March 6, 2002 21:44
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
