Diesel injection problem
Old   May 16, 2012, 14:44
Default Diesel injection problem
Juraj
Jurek is on a distinguished road
Hi all,
i want to ask you for an advice for my problem with direct injection.
I have problem with setting injection. In fact i have injector with five nozzles with diameters 0.36 mm. Flow rate through one nozzle is 0.004 kg/s. Injection time is about 0,002758 s. Required value of injected fuel in chamber is approximately 2,535e-5 kg. I simulate for each nozzle new injection with different direction. My problem is that after injection when i click on reports - summary - all injections (5) i get a summary for injections and there total mass.
And this mass is about one order smaller as i need. I used this parameters:
injection type-solid-cone, number of particle streams-i dont know how many, because o dont know what does it mean, particle type-droplet, material - n-heptan. X,Y,Z positon-clear, diameter -??(0,36)??, temp-320K, start CA-336, stop CA-358, X,Y,Z axis-clear, velocity magnitude -???, cone angle - 5, radius - ??, total flow rate - 0,004.
For any advice thank you.
Jurek
juraj.saniga@yahoo.com
Jurek is offline   Reply With Quote
Old   November 18, 2015, 09:19
giantstp2 is on a distinguished road
Hi Jurek!
I'm also facing the same problem. I can't figure out these parameteres, although i've gone through on Fluent User's Guide.
If someone has any advice, it will be appreciated.
Regards, Adam
giantstp2 is offline   Reply With Quote
Old   June 16, 2017, 06:05
adam
poutivar is on a distinguished road
Is somene still interested in diesel injection ??
Sent from my GT-I9505 using CFD Online Forum mobile app
poutivar is offline   Reply With Quote
DPM mass problem Henrik Ström FLUENT 9 May 20, 2016 11:00
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 05:29
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
