Velocity profile for fluid partially filled in pipe
Old   September 18, 2012, 08:14
Question Velocity profile for fluid partially filled in pipe
Rohit kumar Mittal
rkmittal1108@gmail.com is on a distinguished road
Hi
I would be a great thankful to those who will help me in solving out this problem-
How to get the velocity and pressure profile for liquid flowing through the pipe which is half filled??????? how shall we do modelling and meshing for it also?
rkmittal1108@gmail.com is offline   Reply With Quote
Old   September 19, 2012, 01:44
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Profile:
Why don't you do a second simulation of just a long pipe? Use some arbitrary boundary conditions at the inlet and at the outlet you will get a correct profile. That's what I do to get correct profiles for single phase pipes.
Modelling:
Sounds like the perfect spot for the VOF multiphase model, right?
Meshing:
No idea. I think it will be necessary to refine the grid along the water / air surface, right?
RodriguezFatz is offline   Reply With Quote
3D UDF Paraboilc Velocity Profile (Can't Maintain) Sing FLUENT 12 August 7, 2017 06:25
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 19:08
Velocity profile disturbance due to loss coefficient rks171 Main CFD Forum 3 May 25, 2012 17:30
axial velocity in bend pipe with adverse pressure gradient liguifan OpenFOAM 0 July 24, 2011 05:56
problem with velocity inlet profile file Duncan FLUENT 3 November 21, 2005 07:28
