There is no transfer of heat, I can not find the error.
Old   March 13, 2012, 12:53
Default There is no transfer of heat, I can not find the error.
Vasia Pupkin
Gebbels is on a distinguished road
Dear engeneers, need your help!
I build mesh for the study of heat transfer between the hot solid-source and stream of fluid. I build mesh in ANSYS Meshing. But in Fluent I did not see any heat transfer (you can see everything on screen). All settings are checked and now I think it may be here in the grid. Flow pattern is normal, but there is no heat. Who is not difficult to see the project please what's wrong?
http://narod.ru/disk/43618608001.1c8...nt_11.rar.html
p.s. Geometry did in DM, two solids collected in one part, for build a conformal mesh. I found a few topics on this issue, but the error still can not see.
Gebbels is offline   Reply With Quote
Old   March 13, 2012, 13:19
robboflea is on a distinguished road
Are you doing conjugate heat transfer studies? From the pictures it seems that the fluid and the solid they actually have different temperatures (even if the temperature distribution inside the solid looks not good at all) so there MUST be heat transfer.
How do you get no heat transfer from? What are your boundary conditions?
Cheers
Rob
robboflea is offline   Reply With Quote
polynomial thermophysical properties II sebastian OpenFOAM Running, Solving & CFD 54 November 21, 2019 07:12
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 18:54
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
