Running NASA rotor 67 case on FLUENT
Old   January 9, 2013, 14:43
Default Running NASA rotor 67 case on FLUENT
Raditya Wiranegara
radix is on a distinguished road
Has anybody a case of NASA rotor 67 on FLUENT? I have been trying to simulate this case for a couple of months with no convincing results.
I built the mesh with maximum skewness of 0.84. Is this a possible skewness to run the case in FLUENT? The difficulty in meshing the rotor, due to the twisting from the hub to the tip, is to get a structured mesh with low skewness number.
I am willingly to provide any data should it be required to help you understand the problem.
Regards,
Raditya
radix is offline   Reply With Quote
Old   April 30, 2014, 15:36
RacMat
rvl565 is on a distinguished road
Were you able to simulate the rotor?
rvl565 is offline   Reply With Quote
Old   April 30, 2014, 17:51
Behrooz Jamshidi
CFD-fellow is on a distinguished road
Hi
You can use facial boundary layer mesh in Gambit(its easy and fast)
OR introduce your geometry to BLADEGEN (this is difficult) then mesh with TurboGrid (it gives really high quality hex. mesh)
Regards
CFD-fellow is offline   Reply With Quote
Old   April 30, 2014, 22:26
RacMat
Originally Posted by CFD-fellow View Post
Hi
Regards
Have you simulated rotor 67? I wanted a little help with my simulation.
Old   May 1, 2014, 10:05
Behrooz Jamshidi
Hi
No, but Ive done some turbomachinery analyses with high accuracy(most with water as working fluid).
You can ask your questions. Have you read this?:
http://hv.diva-portal.org/smash/get/...FULLTEXT01.pdf
Regards
Old   May 2, 2014, 14:19
RacMat
thanks a lot for the reply!
I started a thread regarding this, ( i have explained my problem in detail)
http://www.cfd-online.com/Forums/flu...on-fluent.html
Yes i have read the report.
Can you help me with this?
Case running in serial, but Parallel run gives error atmcfd OpenFOAM Running, Solving & CFD 18 March 26, 2016 12:40
force to wait MATLAB for running parallel fluent in batch mode a.latifi Main CFD Forum 1 May 9, 2013 16:44
Problems on running first case VSass OpenFOAM Running, Solving & CFD 0 November 20, 2012 11:26
running fluent parallel with MS job scheduler Shamoon Jamshed FLUENT 0 November 15, 2009 12:48
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
