Hypermesh Exporting
Old   April 3, 2012, 18:16
Default Hypermesh Exporting
eishinsnsayshin is on a distinguished road
Hi All,
I'm trying to export pressures on a surface in FLUENT as a hmascii file to be read in Hypermesh...I'm pretty new to Hypermesh so bare with me. I'm trying to use FLUENT's export>solution_data option but I see no hmascii option available. I've learned if I don't run fluent using parallel processors I can see an ascii option available but no hmascii. Anyone have any ideas how to get hypermesh to read these pressures? Is there another file type other than hmascii that can be exported from fluent to be read in Hypermesh?
Thanks in advance for any advise!
eishinsnsayshin is offline   Reply With Quote
Old   April 3, 2012, 18:20
Pauli
Pauli is on a distinguished road
I would look for Nastran. It is usually supported.
Pauli is offline   Reply With Quote
Old   April 3, 2012, 18:28
Hey thanks for the reply!! That was quick. FLUENT will let me export a NASTRAN but it writes a BDF file which Hypermesh doesn't want to read...
Old   November 26, 2012, 22:20
Default Hypermesh exporting to STL (ASCII)
dirty trucker
jdwarren is on a distinguished road
Greetings. I am attempting to export a mesh consisting of 2D triangular elements in STL/ASCII format in Hypermesh 11.0. Every time I attempt the export, I get the attached error message.
The number of elements "not defined in the template" (244684) is the total number of elements in the model. Does anyone have any familiarity with this sort of error message?
Thanks in advance.
jdwarren is offline   Reply With Quote
Old   November 27, 2012, 07:10
scu
biomechanics is on a distinguished road
chose ansys as template, and export fem model as *.cdb format
biomechanics is offline   Reply With Quote
Old   November 27, 2012, 22:39
dirty trucker
When you say "template," are you talking about the user profile? I can do that, but .cdb does not show up as an export option. Also, I'm not familiar with that particular format -- will it be compatible with software expecting an STL?
Thanks for the reply.
Old   November 28, 2012, 05:23
scu
cdb as the suffix, you can enter *.cdb , and fluent will import the file
Old   November 28, 2012, 22:29
mosgef is on a distinguished road
I've had reasonably good luck exporting surface pressures as Abaqus *.inp files and reading those into hypermesh. FLUENT will export a file that contains both the node and elements defining the surface and the pressures acting on those nodes.
Available from the export--solution data menu
mosgef is offline   Reply With Quote
Old   November 29, 2012, 00:29
Default oops...
dirty trucker
Looks like I'm in the wrong subforum; I actually need this exported in STL format in order to read it into 3-matic (not Fluent). I'll repost in the main CFD forum. Thanks anyway, though.
Hypermesh file to Fluent Logesh FLUENT 1 November 30, 2011 13:46
Compatibility of FLUENT & Hypermesh preshitupadhye FLUENT 0 October 27, 2010 11:47
Exporting mesh from FLUENT to HYPERMESH or LS-DYNA Subramani Sockalingam Main CFD Forum 3 February 19, 2008 07:34
Exporting mesh from FLUENT to HYPERMESH or LS-DYNA Subramani Sockalingam FLUENT 1 February 4, 2008 04:27
Exporting HyperMesh file to fluent 5 Ricardo FLUENT 0 July 6, 2000 04:18
