How can I use NITA in VOF and UDS (separately)?
Old   April 9, 2012, 19:20
Default How can I use NITA in VOF and UDS (separately)?
Igor
DaddySpeleo is on a distinguished road
Hi!
My task contains two part.
1. I solve UDS.
2. Then I use obtained data as source term and try to solve task with VOF and NITA.
(and I want to repeat it some times)
But... If I have UDS - of course turned off in EQUATIONS - I got message: "noniterative solver is not available with UDS."
What can I do to fix it?
Of cource I can remove UDS -but then I lose the data.
Best regards...
DaddySpeleo is offline   Reply With Quote
Old   April 19, 2012, 09:44
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
According to the tasks you need to accomplish you may consider the use of user defined memories instead. Usually the biggest difficulty is in the computation of gradients which require some additional coding (a Green-Gauss cell based algorithm can be easy to be done). Sometimes (but probably not now), the temperature equation can be used conveniently
sbaffini is offline   Reply With Quote
Old   April 19, 2012, 13:11
Igor
Yes. Now I use UDM and copy data from UDS to UDM, then remove UDS, then solve VOF, then create UDS... And I should do it ten times.
I do not understand the creators of Fluent in this case... but - it is the method to stimulate study of Scheme-programming.
nita, uds, vof
melting + vof modeeling for PCM in air taw FLUENT 2 August 24, 2018 00:21
need help about UDS & VOF mengyue1 FLUENT 7 February 7, 2014 17:40
How can i set different diffusivities for UDS using VOF? DaddySpeleo FLUENT 1 March 28, 2012 18:57
Doubts UDS Flux, UDS Unsteady for VOF model kel85uk FLUENT 0 March 17, 2010 08:53
Urgent! Access violation of UDF using VOF Rucy FLUENT 0 January 9, 2006 04:01
