Periodic Boundary condition.
Old   April 13, 2012, 11:32
Default Periodic Boundary condition.
A7A
AHMAD
A7A is on a distinguished road
Hi.
I have a problem in making a periodic boundary condition, it happens when i try to make my mesh finer. fluent gives me this Error.
Warning: differing number of faces on these threads.
computed translation deltas: 0.100000 -0.000126
zone 20016: matched 83 out of 83 faces.
zone 30021: matched 83 out of 84 faces.
Error: Failed to make zones periodic.
Error Object: #f
Thank you.
A7A is offline   Reply With Quote
Old   April 16, 2012, 05:16
robboflea is on a distinguished road
with what software did you build your mesh? Using ICEM? Have you checked your mesh for errors? What did you obtain?
robboflea is offline   Reply With Quote
Old   April 16, 2012, 21:32
Lucky
Originally Posted by A7A View Post
Hi.
Error Object: #f
Thank you.
Lots of reasons can cause this error. But first, make sure you're in double precision.
It looks like you are using auto compute. Are the translation deltas even correct? Try to input the translation vector manually, it helps.
If that doesn't work, most likely it is a meshing problem.
Old   April 17, 2012, 02:30
A7A
AHMAD
Thank you for your replies,
My problem was because of using a conformal periodic bc, so when i used a non-conformal periodic bc it worked out.
Thanks to banty.
Originally Posted by banty View Post
This is because of the mismatch of cell centroid of two boundary u are trying to make conformal periodic BC.
U first convert the boundary as interface BC and then go to interface panel and make them periodic (Non-conformal). Non-conformal periodic BC also gives the good result.
Old   April 17, 2012, 06:39
Lucky
Thanks to banty.
Next time don't double post.
periodic boundary condition in LES martor FLUENT 3 April 30, 2022 00:20
mixed inflow/outflow downstream boundary condition question peob OpenFOAM Running, Solving & CFD 3 February 3, 2017 10:54
periodic boundary condition (translational) fluent 6.3 haihek FLUENT 3 January 22, 2014 04:10
External Radiation Boundary Condition for Grid Interface CFD XUE FLUENT 0 July 9, 2010 02:53
translational periodic boundary condition Rola Afify FLUENT 2 September 12, 2006 08:39
