Overset (Chimera) with OpenFOAM
Old   October 10, 2005, 10:05
Default Overset (Chimera) with OpenFOAM
Alan
is it possible with FOAM to perform Overset (Chimera) simulations? E.g. I would like to compute a rotating helicopter blade in a free stream. Another example would be to simulate a closing valve where the valve ball is meshed in one mesh and imbedded into a background mesh of the channel geometry.
Thanks a lot for any hints. Alan
Old   October 10, 2005, 10:09
Default Re: Overset (Chimera) with OpenFOAM
Hrvoje Jasak
Nope, no Chimera meshes are allowed. The mesh support is for arbitrary polyhedral meshes but the space needs to be filled without overlap.
If you want to do cases like valve or a rotating helicopter blade, you should use the sliding mesh capability. This means you've got two meshes next to each other and one rotates relative to the other. At every time step, they get re-connected by re-creating the interface faces. Have a look at the icoTopoFoam example on a mixer vessel.
Enjoy,
Hrv
Old   October 10, 2005, 12:44
Alan
Thanks a lot for your comments (puno vam hvala).
Can I handle completely closing valves with OpenFOAM? E.i. the gap becomes zero and the flow seases - or the other way round: a completely closed valve opens up because of increasing pressure force?
I will test out your suggestions (and probably come back with a lot of questions
- Alan
Old   January 30, 2010, 00:11
David Boger
boger is on a distinguished road
Well, it is possible. See http://www.cfd-online.com/Forums/ope...tml#post244266
David A. Boger
boger is offline   Reply With Quote
Old   February 2, 2010, 10:03
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
Hi, David,
I am very impressed by your work on integrating overset with OpenFOAM.
I am wondering if we can discuss your work in more detail?
My email is: phsieh2005@yahoo.com
Thanks!
Pei
phsieh2005 is offline   Reply With Quote
Old   February 8, 2010, 00:32
Default Chimera
Johannes N Theron
jantheron is on a distinguished road
David
Do you have any plans to release your overset grid functionality to the wider OpenFOAM community?
Thanks!
Dr. Johannes Theron
KanoeFabrik
jantheron is offline   Reply With Quote
Old   February 8, 2010, 07:00
David Boger
We are unfortunately not permitted to give out the library at this time, but we will try to share our experiences and some of the details of the implementation at the upcoming OpenFOAM workshops.
David A. Boger
Old   February 8, 2010, 08:40
Johannes N Theron
Is this because of restrictions having been placed on DirtLib and Sugarr?
Jan
Getting Started with OpenFOAM wyldckat OpenFOAM 25 August 14, 2022 13:55
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin cfd.direct OpenFOAM Announcements from Other Sources 0 September 21, 2016 11:50
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 03:19
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
The OpenFOAM extensions project mbeaudoin OpenFOAM 16 October 9, 2007 09:33
