wall temperature fixedGradient in buoyantBoussinesqSimpleFoam
Old   February 8, 2010, 10:05
Default wall temperature fixedGradient in buoyantBoussinesqSimpleFoam
David
David_010 is on a distinguished road
Hi
I'm trying to simulate flow inside a circular duct with constan heat flux in the wall. To do that I have imposed a temperature fixedGradient b.c at the wall, but the results are not logical: the temperature at the wall is constant and it must be increasing with the axial longitude. Moreover, the axial temperature profile is also constant with the axial longitude. I think is a problem with the fixedGradient b.c but I donīt know what, because the relation
q=k·(Temperature gradient)
must be met in the wall.
I'm simulating laminar flow (laminar RASmodel). I will be glad if anyone can explain how does it work or how exactly I can impose a heat flux.
Thankyou very much
David_010 is offline   Reply With Quote
Wall Normal Temperature Gradient Daniel Tanner FLUENT 6 September 20, 2015 13:10
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
Constant wall heat flux with uniform temperature Jake FLUENT 2 September 29, 2003 11:34
About fix wall temperature in wall boundary joon Siemens 2 March 10, 2003 01:41
