Pressure correction in fractional step method
Old   May 13, 2012, 18:08
Default Pressure correction in fractional step method
Peter
new_at_this is on a distinguished road
Can someone explain to me how the pressure correction step works in cylindrical coordinates? I have been working on a code for a while and my pressure correction step is not producing a divergence free field.
new_at_this is offline   Reply With Quote
Old   May 14, 2012, 03:44
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
did you check if your method is divergence-free in Cartesian coordinates? fractional step is a method to split pressure and velocity in the time integration, the system of coordinate is not involved
FMDenaro is offline   Reply With Quote
Old   May 14, 2012, 10:18
rmh26 is on a distinguished road
How does the divergence change before and after the correction step?
Is the divergence localized in certain regions after the correction step?
How accurately is your pressure equation being solved?
Are you using an axisymmetric cylindrical grid, is weird stuff happening at the axis of symmetry?
rmh26 is offline   Reply With Quote
Old   May 14, 2012, 11:11
Peter
I do have a working code in cartesian coordinates that has been verified against ghia for the lid driven cavity. I'm a bit confused about what you are saying... Are you saying I should use the exact same pressure correction step for cylindrical coordinates even though the divergence is different?
I am using an axisymmetric grid to solve for the internal flow in a cylinder. Before the pressure correction, the maximum divergence in the field is on the order of 10^-1. After the correction step, it is on the order of 10^-2. After the pressure correction step, the majority of the field has a divergence on the order of 10^-3 and the max divergence values are located in the upper left and right corners near the cylinder wall. In my 2D code I get divergence values orders of magnitude smaller.
I initially start with a velocity profile of 1 everywhere in the field. When integrated it produces a value of 1. I expect that at any time, if I integrate the velocity profile, I should also get a value of 1. However as my flow progresses to steady state, I get values up to 1.2
Old   May 14, 2012, 11:19
Are you using an exact or approximate projection method?
You must be careful in the inner-outer product of discretized divergence-gradient operators
Old   May 14, 2012, 11:38
Peter
I believe that i am using an exact projection method. In each step of my code I update the u_z and u_r field by the advection and diffusion terms. Then I solve the following equation
\frac{\partial^2 P}{\partial z^2}+\frac{\partial^2 P}{\partial r^2}+\frac{1}{r}\frac{\partial P}{\partial r} = \frac{\partial u_z}{\partial z}+\frac{\partial u_r}{\partial r}+\frac{u_r}{r}
Could you clarify more about the inner outer divergence-gradient operators?
Old   May 14, 2012, 11:43
The pressure equation must be discretized from the Div Grad (*) operators, you should not use the Laplace operator. This allows you to substitute the correct BC in terms of the normal component of the pressure gradient
Old   May 14, 2012, 12:01
Peter
So instead of solving for the pressure in one step, could I split it into two steps? the first step would be multiplying the divergence of the intermediate velocity (not divergent free) by the inverse of the discretized divergence matrix. Then multiply that result by the inverse of the discretized gradient matrix.
Old   May 14, 2012, 13:24
Peter
Also are there any books or papers that I can look up that talk about how to do this?
Old   May 16, 2012, 12:18
Peter
for those interested, I found this paper which essentially talks about my problem. Unfortunately I still have not found the bug in my code. I expect my code to produce a poiseuielle like profile that peaks at 1.5 however my code peaks at ~1.8 and is not divergence free.
If anyone has seen similar problems, please let me know. thanks
http://www.sciencedirect.com/science...45793004001148
Old   May 16, 2012, 17:09
Arjun
arjun will become famous soon enougharjun will become famous soon enough
How do you arrive at this equation?? If it is a pressure correction equation then it should have a 'delta-t' term somewhere!!!
arjun is offline   Reply With Quote
Old   May 16, 2012, 17:16
maybe the time step is simply inserted in the P variable ...
Old   May 16, 2012, 17:24
Peter
the equation is just the cylindrical expansion for:
\nabla^2 P = \nabla \cdot  \bar{u}
I didn't put in the time because it cancels once applied in the navier stokes equations.
I have checked and I don't think that is the problem.
Old   May 16, 2012, 17:29
is not a problem if you then compute
V
n+1= V* - Grad P
In any case, I am quite sure you have problems in setting pressure BCs ... you must write Div (Grad P) and substitute n.Grad P at boundaries
Old   May 16, 2012, 17:39
Peter
I think I have accounted for that. Since my code is on a staggered grid, I'm only calculating pressure at the interior points. At the edges, I assume that the ghost point outside the boundary is the same as the first interior point. For example the second derivative in the R direction should be \frac{P_{i-1}-2P_{i}+P_{i+1}}{\Delta r}. Substituting for neumann bcs I get \frac{-P_{i}+P_{i+1}}{\Delta r} at the axis and \frac{P_{i-1}-P_{i}}{\Delta r} at the wall.
Old   May 16, 2012, 18:32
Arjun
I do not have time right now to figure this out. But I will try to imbibe what you wrote.
I am assuming the P in your equation is pressure correction and not the pressure itself.
I asked that because I never remember deriving pressure correction in fractional step method that is independent of delta T.
Old   May 16, 2012, 19:21
Arjun
You can not apply zero gradient at the axis by ghost points. Axis has pressure gradients.
Yes this is the case, he is calculating for ( deltT * Pressure-correction).
Old   May 17, 2012, 10:57
There normal component of the gradient of the pressure should be zero at the axis, if we are assuming axisymmetric flow and the fact that Ur must be zero at the axis.
What are you using for the inlet/oulet conditions?
Old   May 18, 2012, 11:56
Peter
So i'm working on a sliding cylinder problem, which is axisymmetric. Basically its a cylindrical cavity where the end caps are stationary and the wall is moving with a given velocity in the z direction. So expect that the pressure gradient at the axis should be zero. I've defined U_r to be 0 at all the boundaries. U_z has a velocity of 1 at the outer wall and symmetry condition at the axis.
If anyone is interested or if anyone thinks seeing the code might help, then i can post my matlab code. I'm pretty sure that this poisson equation solver is the last bug in my code.
Old   May 22, 2012, 00:04
Peter
I think I figured out where the error is. When I formulate the finite difference matrix for the laplacian, I essentially solve Ax = b. However A is nearly singular and so my solution ends up being innacurate. How can I increase the accuracy?
Comparing between the Fractional step method and the SIMPLE method ghlee Main CFD Forum 1 April 10, 2012 16:59
Time Accuracy of the NITA - FRACTIONAL STEP method Paolo Lampitella FLUENT 1 March 19, 2008 05:45
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
free surface bc using pressure correction method Sal Main CFD Forum 0 March 10, 2007 15:50
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
