About "Release" mode
Old   November 29, 2005, 07:11
Default About "Release" mode
Alex
I use Fortran powerstation. Although the code runs O.K. under "Debug" mode, there are strange mistakes occuring under "Release" mode. Has anybody met such situation?
Old   November 29, 2005, 09:30
Default Re: About "Release" mode
buch
You should carefully check all the options you use in the release mode. In particular, the reordering of operations or the loop transformation can induce errors.
Regards
Buch
Old   November 29, 2005, 19:54
Alex
Thank! But why in "debug" mode, we cannot see the mistake?
Old   November 30, 2005, 04:24
buch
Usually in the debug mode you do not see the mistakes due to the optimizations simply because the optimisation options are turned off ;-)
You may try to use the release mode, increasing the number of compilation options asked for efficiency.
I think your compiler manual will be of great help to identify, and possibly turn off, which optimisation options are the most "agressive".
Good luck
Buch
Extend Project Release 1.6-ext hjasak OpenFOAM Announcements from Other Sources 33 July 14, 2011 18:54
Grid Check Fails in Parallel Processing Mode askance Main CFD Forum 0 October 20, 2010 10:11
OpenCFD release OpenFOAMŪ version 1.7.1 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 August 26, 2010 11:40
Diesel combustion simulation ( Heat release rate) venkatesh Siemens 2 April 29, 2009 07:38
Public Release of the Wiki Jonas Larsson CFD-Wiki 3 November 7, 2005 04:13
