November 14, 2005, 09:47 |
Recommend Visualization software for FVM
hi,
i'm looking for a easy to use visualization software to visualize the data i obtain from the FVM code. I was using tecplot but it doesn't seem to be very suitable. there also seems to be some errors when i try to interpolate the values when using cell center display. since i'm using fortran, i hope the data format isn't too complex. it should preferably be able to show cell center and node center values at the same time. of course, if it's free that's even better.... thanks alot! |
November 14, 2005, 10:39 |
Re: Recommend Visualization software for FVM
You can try to use Paraview (http://www.paraview.org). It's free and easy to use (for me...).
I've been also using Fortran and among several file formats supported by Paraview I've been using the Ensight 6 format. By this way I can use both softwares to visualize my results. here you can download my Fortran routines to write primitive CFD data in Ensight format http://www.nacad.ufrj.br/~rnelias/paraview and to find other visualization softwares see the following link: http://www.cfd-online.com/Links/soft.html#vis Cheers Renato. |
November 14, 2005, 12:28 |
I would recommend paraview, too. And for further calculations: octave with the octaviz package Fabian |
November 14, 2005, 21:42 |
Thanks alot! I'll give paraview a try, together with Renato's fortran routine.
November 14, 2005, 23:18 |
hi, may i know if there's any manual or tutorials to help get started? thanks
November 15, 2005, 06:47 |
This is the problem...
Despite being free, Kitware sells the user guides and courses for their softwares - they need to earn money from some place, of course ;o) But, I can tell you that Paraview was the easiest visualization software I've ever faced with and I think you won't have problems working with it. There was a short user guide for the version 1.6 available in Paraview's website but I can't find it anymore, so let me know your mail that I can send it for you... Cheers Renato. note 1: Don't forget to download the tutorials data. note 2: My routines write only the geometry and result files for velocity and pressure. You'll have to write a very simple casefile in order to load Ensight's file in Paraview. You can find examples of casefiles in the tutorial data or in the Ensight's guide I've zipped with the routines. |
November 15, 2005, 10:30 |
Visualization Software for CFD | Paul | Main CFD Forum | 3 | March 25, 2006 17:16 |
Recommend software for simple post processing | zonexo | Main CFD Forum | 5 | March 4, 2006 03:20 |
Free visualization software? | Martin S. Rasmussen | CFX | 0 | December 20, 2002 08:33 |
Free Visualization Software | Christian Tollschein | Main CFD Forum | 1 | August 19, 1999 14:15 |
Seeking for flow field (vector plot) visualization software. | Hua | Main CFD Forum | 7 | January 25, 1999 11:33 |
