Simulation of Two Phase Fluid Flow Problem Using Fluent 5.0 |
July 16, 1999, 12:15 |
I would like to simulate a laminar, incompressible, and steady state flow problem of two phases, air-water within a cavity of toroidal shaped geometry. Can it be simulated by using Fluent 5.0 ? Thanks Mohammad |
July 16, 1999, 12:28 |
Re: Simulation of Two Phase Fluid Flow Problem Using Fluent 5.0
Dear client,
Yes you can. If the flow is a stratified one with a free surface between air and water, you can use Volume-of-fluid (VOF) method in FLUENT 5. If it is a two-phase flow where air-water interafce is not clearly defined (e.g., blbbly flow), you can count on our mixture model (algebraic slip micture model) in FLUENT 5. Please take a look at the users; guide first. And if you have any question, please contact your support engineer at the nearest Fluent office. |
basic fluid flow problem - is there a way to switch pressure to a flow rate in analyt | vlnikolic | Main CFD Forum | 3 | September 16, 2016 05:07 |
why is solid temperature same as fluid temperature on flow simulation ? | qihongming | FloEFD, FloWorks & FloTHERM | 0 | May 26, 2009 09:57 |
Two phase flow - Euler in Fluent | MartinP | FLUENT | 0 | November 3, 2006 11:07 |
problem of river flow simulation | Liu | Main CFD Forum | 0 | May 27, 2004 23:01 |
Problem on boundry of two phase flow | youngan | CFX | 2 | June 30, 2003 03:11 |
