The SIMPLE algorithm is not too simple for me |
June 12, 2012, 04:39 |
Zeke Angels
I try to simulate the gas flowing through a tube filled with spherical particles in the steadystate regime. The equations are solved using the finite volume method and I try to implement the SIMPLE algorithm to get the correct pressure and velocity fields that satisfy both continuity and momentum equations. I tried for a week to solve the problem but I didn't manage to do it correctly.(I got negative velocities at some nodes ) I will be happy if some one can give me a clue on how to solve the problem. You will find a detailed description of the procedure I adopted in the pdf file attached to this post. Thank you in advance, Zeke. |
June 13, 2012, 18:36 |
#2 | |
June 18, 2012, 04:06 |
Zeke Angels
Hi Ztdep,
I will try to understand the global fortran code. Thank you for your help and have a nice day, Zeke. |
SIMPLE algorithm in 3D cylindrical coordinates | zouchu | Main CFD Forum | 1 | January 20, 2014 17:02 |
About simple algorithm in simpleFoam | JinBiao | OpenFOAM Running, Solving & CFD | 0 | December 15, 2011 02:06 |
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm | Yan Kai | Main CFD Forum | 0 | April 18, 2007 03:48 |
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm | Yan Kai | FLUENT | 0 | April 13, 2007 23:17 |
SIMPLE algorithm | Jonathan Castro | Main CFD Forum | 3 | December 10, 1999 04:59 |
