Comparison: TecPlot vs. PARAview
Old   December 4, 2005, 22:25
Default Comparison: TecPlot vs. PARAview
Michail
Dear colleagues
What can do one, and what can not do the other?
Any suggestions are highly appreciated.
Michail
Old   December 5, 2005, 00:27
Default Re: Comparison: TecPlot vs. PARAview
dpshaka
PARAVIEW IS A FREE SOFTWARE
TECPLOT IS A COMERCIAL SOFTWARE
AND THE SUPORT OF THE PARAVIEW IS LITTLE.
THE DATA FORMAT IS EASY TO UNDERSTAND FOR THE TECPLOT.
TECPLOT IS EASY TO USE.
Old   December 5, 2005, 04:45
andy
As dpshaka says, tecplot is commercial software and paraview is freeish (ish because you need to spend about 150 euros on a couple of books to get the documentation).
We have recently looked at 3D plotters but commercial programs like fieldview and tecplot are not viable because of the cost (impoverished university requiring lots of copies on a range of platforms). The choice was effectively between paraview and visit and we opted to stick with the latter although we will support both eventually. They have different strengths and weaknesses but, extraordinarily, paraview does not seem to support multi block structured grids and we are not going to write such software for it without documentation. Anyone know of such a reader? There is no documentation available for paraview until "early 2006" whenever that may be.
Although the commercial software is still better for student use both these programs have evolved from poorish a few years ago to really quite usable today. This is encouraging for the future at least until support for one or both the projects gets axed which happened to paraview for a year or two.
Paraview has a bit more plotting capability but the better file type support (for our uses) and documentation of visit currently gives it the edge for our purposes.
Old   December 5, 2005, 06:59
Renato.
Well, you don't need to buy Paraview's books to start using it. I began to use Paraview only using a short description of the software and I thought the software so easy to work that any book was necessary to learn the main features.
Regarding the other questions:
- Version 2.4.x of Paraview supports multi-blocks structured and unstructured
- Support: I think that Paraview's mailing list is much more userful/helpful than any other kind of support. You just put your question and wait a few minutes to get your answer;
- File format: Paraview give you support for at least 30 file formats, including some famous formats such as: Ensight, Plot3D, HDF5, etc... . Ensight, for me, is the easiest file format I've ever faced with.
Another issue that must be considered is that Paraview has been frequently developed and most of the "desired" features were not implemented/tested yet. For example: the multi-block reader was just implemented in version 2.4.x.
regarding VISIT... I'm still trying to read my Ensight case files in it without any success yet. The same file that is read by Ensight and Paraview, VISIT is not able to read and I can't figure out why yet.
regarding Tecplot... I tried Tecplot some time ago but the first few minutes with a software are enough, for me, determine if this software is easy or hard (for me again) to use and I ended giving up. Tecplot realy seems to be powerful but I was not able to use it.
Regards
Renato.
Old   December 5, 2005, 10:37
andy
I have the vtk file format documentation for 4.2 and there is no support for multi-block. Do you have a pointer to documentation of this recently added capability?
Old   December 5, 2005, 16:38
Renato.
Hi Andy,
take a look in the following message (specially the first item) to see if it's what you're looking for.
http://public.kitware.com/pipermail/...er/002152.html
Regards
Renato.
Old   December 5, 2005, 20:42
Adrin Gharakhani
I have not used either paraview or visit ... How about plotting speed, especially for large unsteady data files? How is the support for parallel/distributed data?
Adrin Gharakhani
Old   December 6, 2005, 03:49
andy
Thanks for the link. I downloaded and installed the latest stable version, read the source code and it has only partial support for multi block grids.
They have added a new class to the guts of vtk which presumably handles multiblocks although I did not read it to find out what (no documentation and C++ inheritance makes browsing someone elses code structure very hard work). There was a note about missing functionality but I did not understand the vtk-speak to appreciate what it was.
Multiblock is in the Plot3D reader but the Plot3D reader is only partially implemented and it will only read velocity and 2 thermo properties and not other variables like acoustic, electric and magnetic fields, species, etc...
Multiblock has started being added to the native vtk file format but is incomplete with most of the functions being empty in the reader. There is an example of how to write some C++ code to get multiblock into vtk but how well supported the connectivity and handling of ghost cells is I do not know. The parameters I would expect to see were not in evidence.
I did not look at the ensight code but there is no specific reader for multiblock unlike the other two formats. However, ensights format may not need something extra it in order to define multiblocks.
I could have greped to see what uses the new class but I had pretty much established paraview still cannot do what we want and we are better off sticking with visit and waiting for parview to evolve a bit more.
Of course, this whole exercise (about an hour including download) demonstrates the wisdom of using open source in a research/teaching environment. We have answered the questions we needed and could have added the code if the need to use paraview was urgent. This could not have done this with tecplot, fieldview or similar. Although I should add that I received good support getting round bugs in fieldview when I used it for a while. Cannot comment on tecplot support.
Old   November 16, 2012, 08:09
Cheng Jie
jiec827 is on a distinguished road
Originally Posted by Michail
;39146
Dear colleagues
Michail
Excuse me! I am new here...
I want to know how to import Fluent cases and .dat into Paraview?
THX
jiec827 is offline   Reply With Quote
Old   July 25, 2013, 09:46
Arina
Akuji is on a distinguished road
Send a message via ICQ to Akuji
Hello!
Is it possible to open vtk in Tecplot?
If not, maybe you can suggest some converters form vtk to tecplot.
Akuji is offline   Reply With Quote
Old   January 16, 2018, 00:00
Default Tecplot can support VTK
  #11
Andhra Pradesh
manohar1487 is on a distinguished road
HI Akuj,
Tecplot can support VTK now.
New VTK loader that supports .pvtu, .vtu, and .vtm file formats provide compatibility with COMSOL, Envenio, SimVascular and PyFR.
Regards,
Manohar
manohar1487 is offline   Reply With Quote
Old   January 16, 2018, 00:01
Andhra Pradesh
HI Akuj,
Regards,
Manohar
Old   August 18, 2022, 15:46
Brandon M
Brandon_CFD is on a distinguished road
Also, you can convert many of the VTK file formats to Tecplot format with the following Python script from the PyTecplot GitHub (also see the directory for other file converter scripts):
https://github.com/Tecplot/handyscri...e_converter.py
Brandon_CFD is offline   Reply With Quote
[General] Convert Tecplot DAT files to ParaView redable one B. R. Guirguis ParaView 7 September 8, 2023 06:38
ParaView and Tecplot 360 'has stopped working' on windows zhenglun.wei OpenFOAM 0 June 27, 2011 17:29
ParaView and Tecplot 360 'has stopped working' on windows zhenglun.wei Main CFD Forum 0 June 27, 2011 11:49
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
TecPlot VS ParaView B. R. Guirguis Main CFD Forum 0 February 27, 2006 11:53
