flop count for linear system solvers
Old   December 7, 2005, 16:53
Default flop count for linear system solvers
no_name
Hi All,
does any one have a reference clearly describing how to do a floating/double point count for linear sys. slovers like gauss elemination, cholesky, LU ....ect . For eg. Gauss elem. is O(N^3/3).... how does one come with this estimate ??? explanations, references appreciated ???
thnx.
Old   December 7, 2005, 19:46
Default Re: flop count for linear system solvers
Tiger
Try this website http://www.nr.com/
Other good references are
Linear Algebra and Its Applications Author: Gilbert Strang
Numerical Linear Algebra Author: Lloyd Trefethen
Old   December 7, 2005, 22:10
Ynot
First of all, write down your algorithm as pseudocode. Now simply count the number of operations that the algorithm is doing (per iteration of course). all operations: addition, subtraction, multiplication, and division count the same. This is not exact since multiplication has several additions inside it and division has several multiplications... But it seems reasonable to assume that all operations are the same.
Here is an example (just for illustration):
for i = 0 to P
for n = 1 to N (number of elements in array)
B(n) = a(n)*a(n-1) - 2*c(n) + 3
next n
next i
for each n you have 2 multiplications, one subtraction, and one addition = 2+1+1 = 4 operations. For all the number of elements you therefore have: 4N operations. It is at this stage that you state the order of your algorithm. In this example, its is O(4N) or simply O(N) (constants do not count). For all iterations, you have 4N(P+1) operations. (remember, if u're starting from zero, you are doing p+1 steps).
Hope that was helpful
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Systems of Nonlinear Equations Tanay Main CFD Forum 5 November 2, 2010 15:27
New linear system solvers chegdan OpenFOAM Running, Solving & CFD 11 April 30, 2010 10:22
Need ideas-fuel discharge system Jan CFX 1 October 9, 2006 08:16
[Other] Importing a mesh in system memory using C directly to OpenFoam Solvers juanduque OpenFOAM Meshing & Mesh Conversion 1 August 10, 2006 04:15
