December 7, 2005, 02:29 |
steady state - transient
Hello CFD-friends. A short problem description: flow through a baffle, simple geometry like an elbow divided in several channels, Newtonian, incompressible,2D, inlet-velocity = 24.9 m/s, pressure outlet, fine and good mesh,structured in near wall regions, discretisation scheme: only first-order accurate, nu = 2,8e-5. Analysing the solution brought out big differences in the calculated pressure loss between the steady-state and the transient solution. Has anyone ever experienced huge differences (pressure loss nearly twice as high) between steady-state and transient simulation although the final residuals are of order 1e-7. The flow is obviously unsteady.
December 7, 2005, 16:40 |
Re: steady state - transient
100% is a large difference. I am assuming the unsteady loss is the higher one?
December 8, 2005, 02:00 |
No, the unsteady solution reports a pressure loss of 220 Pa, the steady-state simulation gives a value of 330 Pa. Meanwhile I changed discretisation scheme to second order, but the great differences remain. Software: OpenFoam, solver: simpleFoam - unsteady; turbFoam - transient. Any advice?
December 8, 2005, 15:52 |
It's hard to give advice other than to make sure that the computations are not just converged, but have also been checked for accuracy (experimental data would be invaluable!). Try increasing grid resolution and temporal resolution (unsteady) to the point where the solution doesn't change any more, and make sure your boundary conditions are suitable. Closely examine the unsteady solution (what actually happens over time -- is there some kind of flow instability... some kind of oscillation... ).
One thing that's suspect is the fact that the steady state gives higher losses. I can imagine the opposite situation: if there really is unsteadiness such as a vortex instability, then the creation of vorticity over time will likely be seen as additional loss as compared to the steady state. However, in your case I couldn't trust either steady state or unsteady result. A closer look at both solutions should help to see if either of them actually makes sense. |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Steady State Vs Transient answers | Kushagra | CFX | 25 | July 23, 2017 03:20 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Mass Diffusion: Transient and Steady State BC | rval | CFX | 3 | November 19, 2008 00:52 |
Transient vs Steady State | Adam | CFX | 1 | April 12, 2007 11:34 |
