Exporting a mesh to Elmer CFD
Old   August 3, 2012, 06:45
Default Exporting a mesh to Elmer CFD
bitacovir is on a distinguished road
Hi, everybody.
I have a problem trying to export a mesh 2D from NGSolve to Elmer (CFD software).
At the beginning I tried to open the geometry (step file) with Elmer to generate the mesh. However, it has problems to import 2D geometries and the mesh is generated with defects. Then, I tried with Ngsolve which could open the stp file and generate a good mesh, but now I can't export the file to one format to work with Elmer. Ngsolve doesn't export to Elmer format. I tried to export with the inp format of Abaqus, but the software crush.
I tried to export into a msh format but Elmer fail to open it.
Some suggestion?
bitacovir is offline   Reply With Quote
Old   August 3, 2012, 22:57
I going to ask in a different way.
Wish program do I need to made a 2D mesh to run in a CFD software?
Old   August 4, 2012, 06:29
Praveen. C
praveen is on a distinguished road
Have you tried gmsh ?
praveen is offline   Reply With Quote
Old   August 5, 2012, 22:31
Thanks I will try it.
Old   August 15, 2012, 07:40
Rami Ben-Zvi
Rami is on a distinguished road
If you have access to ANSYS (at least older versions running APDL), there are Elmer Macros to directly export the mesh to ELMER.
Rami is offline   Reply With Quote
Old   August 16, 2012, 06:01
Thanks. Finally, I make the geometry in iges format, then I export the mesh in msh format from NGSolve and with Elmer I can open it without problem.
thanks.
mesh export, mesh format, ngsolve
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
Transport mesh from ICEM CFD, to Fluent, to Sysnoise Wieland FLUENT 2 April 15, 2012 06:28
[Netgen] boundary conditions and mesh exporting vaina74 OpenFOAM Meshing & Mesh Conversion 2 May 27, 2010 09:38
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
