benefits of c-meshing ?
Old   October 25, 2012, 09:46
Default benefits of c-meshing ?
Umut Can
Umuteng is on a distinguished road
Hello everyone,
For 2-d flow over airfoil analysis what is the advantage of c-meshed domain over the unstructured meshing options?
Best regards...
Umuteng is offline   Reply With Quote
Old   October 26, 2012, 12:28
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
Using quadrilateral elements rather than triangular elements is more accurate when using finite volume methods. I'm not sure how much you know about the disretization details, but if you take a line that connects the centroid of two adjacent volumes it does not in general pass through the integration point on the cell face and you will have to apply corrections to get to the right point. If the grid is orthogonal this line passes directly through the integration point, so no correction necessary. The more closely orthogonal the mesh, the smaller this correction will be and the more accurate your results will be (in general).
Also, triangular/tetrahedral meshes don't do as good of a job of resolving boundary layers as quad/hex meshes since the grid lines are in not aligned with the flow.
cdegroot is offline   Reply With Quote
Old   October 29, 2012, 07:36
Ford Prefect's Avatar
Ford Prefect is on a distinguished road
Probably the ease of mesh generation (if you have a more complex geometry), and number of generated cells?
However, you still need to apply a correction in structured body-fitted meshing since you need to calculate a Jacobian. How this affects accuracy compared to the unstructured form of correction should be interesting to know.
I agree on the boundary layer treatment, it poses some additional problems if you use triangular elements in that region.
"Trying is the first step to failure." - Homer Simpson
Ford Prefect is offline   Reply With Quote
Old   October 31, 2012, 16:51
Umut Can
thank you guys, however i think i need more detailed information so could you advice any papers which is related to this phenomena ?
Old   October 31, 2012, 18:06
vicarious's Avatar
Pedram Mojtabavi
vicarious is on a distinguished road
Send a message via Yahoo to vicarious
Because of the accuracy needed for flow prediction close to the walls, specially for an airfoil with high pressure gradients, It is more common to use and structured mesh around these complex geometries. You can produce an uniform cells down to walls and control the Y+ much easier. It also saves time and memory more than unstructured grids. Briefly, boundary layer resolving is much more accurate. Maybe you find the attachment below useful.
http://www.4shared.com/office/an7yoH...rid_Types.html
vicarious is offline   Reply With Quote
Old   October 31, 2012, 18:27
Umut Can
thank you very much for informations, and document you share...
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 05:01
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
